Question about X2Gen MG19MY 19" LCD Monitor
Blank screen screen goes blank randomly, most of the time stays off, had to hook old monitor back up to use computer
  • pearson1_dj Oct 09, 2008
    where would I find a reset on it? this monitor is less than a year old..
  • 63 Answers
If this goes blank randomly, it could be that there's something wrong with the monitor or its starting to die on you. if there's a factory reset button on the monitor, you can try doing it and if that is still not going to resolve the problem then just get it replaced if its still under warranty and if not then get another one.
Posted on Oct 07, 2008
SOURCE:
My monitor goes blank after being on for around 10 seconds. When I reboot the computer the monitor will turn on and off and on and off again. When the computer is booted completely, the monitor goes blank....
hi
It is a little tricky problem. But anyways this is due to small capacitor leak you have to replace it to make it work well. You can identify it by seeing the top of it. See the below pix for more info.
Jul 14, 2011 | Proview PL926WBi 19" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
When energized, screen stays on for about two seconds then blanks
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Nov 15, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Screen only stays on for 2 seconds at a time
just an update...I have fitted a new cable (pc to monitor) and it has been on for 2hrs now so fingers crossed!
Aug 19, 2008 | Philips 19 in. CRT Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
124 people viewed this question
Top X2Gen Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
