Polaroid HDTV no longer shows a picture and there is a blinking red light?
  • dhuff7 Oct 07, 2008
    What do you mean toggle?
  • dhuff7 Oct 08, 2008
    Yes we have.
    The TV doesn't come on at all. We called Polaroid and they suggested changing the fuse, we did that and it still isn't working
  • 749 Answers
Have you toggled the source button on the tv or remote to see if the source has been changed?
Posted on Oct 07, 2008
  • Jeff Strader
    Jeff Strader Oct 08, 2008
    each press of the source button should change the tv from one input to the next
Red status light is on but not blinking and picture wont show at all???
access the self diagnosis feature by pressing the menu and device/input buttons on the tv both together and hold them for 6 seconds then counr the teo digit blink code.
Mar 11, 2013 | Mitsubishi WD-62725 62" Rear Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
I get a red screen and then it goes black no picture i get sound just no pic the red led light blinks 7 times
In most cases on these models the red crt is shorted and causes the set to go into a shutdown mode and flash the timer light 7 times. The part number for the red crt is 8-733-664-25 but is no longer available.
Nov 11, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Polaroid Paper Jam
I had the same promblem and this is how I solved it. If you have an android, screen shot the picture and crop as you desired. Then Press the share button and click bluetooth (Poloroid Zink) and dial in 6-0-0-0 for the password. Only put that in for the password. If it the password entry doesn't come up, that's okay. Hopefully this helped!
Nov 08, 2009 | Polaroid PoGo Digital Photo Printer
I have a blinking red light with no picture
Blinking red light shows TV got some problem internally and need to be repaired.
Now important thing is how many times that red light blinking? There would be pause of 3 seconds in blinks so count pause to pause and let me know to find out possible cause of problem.
Is it Sony KDS-55A2000 model TV or any other model?
Sep 21, 2009 | Sony KDS55A2000 55" HDTV
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Mitsubushi wd 52525 No picture, no sound. Self Dia shows 1.2
No trouble code is 12, is that what your getting? Is red light on all the time or blinking?
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Oct 31, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
