Question about Epson Stylus C84 InkJet Printer
How do i clean the head on my epson stylus C84?
Hi! I dont know what is wrong with this printer, but i put new ink in it and nothing prints out? how do i clean the head(what is this) is that the troubles? THANKS!
  • 68 Answers
You did take the tape of the inks?
Posted on Oct 07, 2008
  • rody3 Oct 08, 2008
    go to print something select properties and the mainenance tab and you can select the print cleaning
Epson Stylus C84 prints every other line.. Cleaned print heads and ran nozzle check...still same problem.
Your printer head may be booked. Follow the instruction given bellow:
1. Open printer cover and put off cartige from cartige chamber.
2. Take a plastic seringe with full of ink and fit it on head's stick. Then push ink carefully.
use this procedure one after another . I thing you may relive from your problem. thank you.
Aug 17, 2010 | Epson Stylus C84 InkJet Printer
C84 stylus - put new cartridges in and it doesn't print full text or all color
Did you use Original Epson Cartridge? I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Nov 29, 2009 | Epson Stylus C84 InkJet Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
Good Luck :0(
Asker's Testimonial
Comments:
Nov 12, 2009
- Funny. hahahahah,
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Good Luck :0(
Nov 12, 2009 | Epson Stylus C84 InkJet Printer
My epson stylus c84 printer does not print
Hi
Thanks for using FixYa. The printer won't operate properly if it's tilted. Place it on a stable and flat surface. Please do not leave your printer turned on when not in use to avoid print heads being clogged. In the instant case the ink cartridges can also leak into the printer. If the print heads are clogged then run the head cleaning and alignment utility. The print head nozzles may also need cleaning.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | Epson Stylus C84 InkJet Printer
Had not used it for a while.. put in new ink..even after several cleanings..it wont even print out a thing
Head cleaning is mechanical proccess, printing is electrical proccess. If nothing at all ink out/spray from head in printing proccess, problem with electricity. Damage board or short circuit at head cable. Check board first, may be some component "burn".Better to take printer to epson service center. Damage board can be replaced, but it must to check the cable head and small circuit at head first.
Aug 17, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Ink printing problem
Did you remove the plastic from the bottom ofthe cartridge, if not do so and changing from vista to xp would change that probelm.
Jamiell
May 13, 2008 | Epson Stylus C84 InkJet Printer
Epson c84 ink cartrages
Hello Carla, can you manually clean the heads where the ink delivers the printer. Try using the printers own program first then do a manual clean with proper cleaning solution if this will not work.
Mar 10, 2008 | Epson Stylus C84 InkJet Printer
Does not print on paper but with new ink replaced
proably is the nozzle in printhead clogged by dry ink because you dont use genuine ink from epson and i suggest a replacement of the head because it is almost impossible to clean it out
Mar 02, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
