Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven door that wont come unlocked
When I put the oven on cleaning mode, I accidently opened the oven door and it was in the lock mode. . . now I can close the door completly. . . and my oven will not turn on? What to do?
  • Anonymous Oct 22, 2008
    This solution worked...5 seconds...THANK YOU!!
  • GE Master
  • 2,651 Answers
Sounds like you have a latch/lock issue. the unit seems to think the door is still currently locked, preventing proper operation, i would try to see if you can locate the door/light switch and manually trip it with your hand(turning off light). then while keeping depressed activate the self clean mode again, the machine will try to engage the lock/latch, as soon as it does then cancel it and it will return back to a normal resting location. you must keep the light switched pushed in order for this to work correctly
Posted on Oct 07, 2008
Thanks for posting that.. it worked for mine as well!
Posted on Oct 25, 2008
2 Suggested Answers
  • 43501 Answers
SOURCE: oven door remains locked after using the oven cleaning feature
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ... > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Door wont unlock
I did that once and had luck unplugging and used a ice cold cloth to cool down the lock handle until it unlocked. Just try not to cook a turkey in the cleaning mode without the fire departments phone number handy.
Nov 23, 2011 | Ovens
Oven door wont open
i was cleaning the oven when they a black out and when the light came on the oven whould not come on and the is still lock what can i do
Jun 01, 2010 | Kenmore 36665 / 36669 Gas Kitchen Range
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Jenn Air oven door won't open after clean cycle
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
327 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
