Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Opening Up a Dell 2005FPW
A Dell 2005FPW we have here has gone on the fritz off-warranty, so I'm dusting off my toolkit to see if I can't figure out what's wrong (pretty sure it's either the inverter or power unit).
Problem: cursory examination and online searches have provided no real clear diagrams of how to get into the guts of the display.
  • akatechnical Oct 22, 2008
    The unit would remain on in stand-by mode displaying the color test pattern, but would begin flashing between the intended video input (i.e. the computer desktop) and black on and off immediately upon having a video input connected to it. This would persist, preventing input switching or even powering off the unit via the power button in front.
    I have found no bulged capacitors in a thorough inspection of the internal device components. Do you have any further advice?
  • kakarot98 Nov 12, 2008
    I cannot take off the back of my monitor, it is stubbornly clipped somehow. I am not I weenie, but I am afraid if I use brute force, I will break it. Does anyone have an easy way of removing the back of this thing?
    Champion:
  • 293 Answers
Hi...there,
If you got power with no screen or both... Then it's your backlight inverter are busted. Need to replaced or repaired. To repaired look for a capacitors with a bulged on top of each caps. Not sure...just replaced all the caps... Good lucks!
Posted on Oct 13, 2008
Dell UltraSharp 2005FPW shut down wont power up.
You can have the board repaired for $50 or you can inspect it first for bad connectionc, bad caps, etc.
http://www.lcdrepair.us/2005fpw-power.html
Apr 22, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
How and where i can find aschematic for dell 2005fpw.
You can start from here if this helps.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
Dec 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Dell 2005fpw flash problem
Often this is a capacitor problem, there have been many problems with them as of late. http://www.badcaps.net/forum post here and they will be able to help you out.
Jun 12, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell 2005fpw inverter purchase
Try:
http://www.lcdrepair.us/2005fp-inverter.html
Jan 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
I have a Dell flatscreen monitor that will not turn on. The power light blinks blue slowly
Hi...there,
It's seems you got a busted backlight inverter. If you still under warranty send it back to Dell for repaired. Happy Holidays!
Dec 18, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell screen
Hi...there,
It's open from the front bezel of the screen. But if you are still under warranty...send it back to Dell for repaired... Happy Holidays!
Dec 05, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
2005 FPW Dell Monitor
Hi D,
Kindly unplug the monitor form the back of the computer and check the display,There would be a self test ,screen that would run on the monitor . Check if the screen in green in the self test.
You can also restore the setting of the monitor to factory reset, sometimes there a static that builds up on the screen and can cause the problem. Press the menu button in the front and use the + or - keys to select factory reset and press menu again.
If nothing of the above works the monitor has gone bad, if the monitor was purchased with the system then it would have the systems warranty.
If you have purchased the monitor on seprate order it would have 3 yr warranty
Thanks
Proton
Sep 11, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
369 people viewed this question
Alun Cox
