Question about Aiwa AM-F70 Personal MiniDisc Player
Caution message on Aiwa AM-F70
My minidisc recorder does not opperate. whether I try to play a minidisc or record, I get the "CAUTION" message. Is my machine trash?
Try another disk if still no go try pressing reset button on bottom of unit.
Posted on Sep 01, 2009
  • humberstone Sep 01, 2009
    try another disk if still no go press reset button on bottom of unit !
HOW DO I SET UP MY KENWOOD MINIDISC RECORDER
A MiniDisc recorder would plug into your stereo system just like a regular old cassette recorder would. Line out from deck to line in/play on receiver/amplifier and Line In from deck to "record" / tape line out from amplifier/receiver.
Insert MiniDisc, select Source and you should be ready to hit 'Record' and then 'Play' to start recording.
Mar 04, 2016 | Audio Players & Recorders
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
I get a protected message up when trying to record -regardless whether the tab is in or out ?
Two possibilities: are you trying to make a digital recording from a digital source? If so, just change to analog. Otherwise, you have have a bad limit switch lever that tells if the MD has the non-record door opened.
Apr 05, 2015 | Audio Players & Recorders
SONY MDS JE 530. (C14) Toc error.
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
Mz-n510 walkman won't play 140 mb disc
No. MZ-n510s cannot play those discs. Buy a HI MD machine or sell the disc.
http://www.minidisc.org/hi-md_faq.html#_q96
Dec 17, 2012 | Sony Net MD Walkman MZ-N510 MiniDisc...
Hi I press record the disc player runs for about 8
Sounds like you are trying to put in too much power. Check that the mains adaptor matches the machine.
Jul 13, 2011 | Aiwa AM-F70 Personal MiniDisc Player
Sale c13 read error
C13 read error means that the player is unable to read the TOC (Table Of Contents) on the minidisc. it has to read this first so that it knows where everything is stored on the minidisc.
TOC errors can be caused by faulty minidiscs, those which have been incorrectly finalised or by a faulty head assembly on the machine.
If possible, try to see if you get the same problem with different brands of minidisc, and also whether minidiscs recorded on other machines work on your player and whether minidiscs recorded on yours work in other players. Report back with what you find as it helps determine whether the player itself is at fault.
In reality though, it's a 9 year old unit and like all optical disc devices, minidisc heads do not last forever. If the head has failed then your only fix is to replace the player as spare parts are no longer in production and existing stocks are almost as rare as fresh dodo doo-doos.
Mar 16, 2010 | Sony MDS-JE470 Mini Disc Player
Tascam 8 track recorder won't play back recording
Does it use MiniDiscs? If so, it cannot work with standard audio MiniDiscs, it requires a special DATA MD.
Jan 21, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
Aiwa AM-F70 Personal MiniDisc Player Logo
331 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
