Question about Acer Aspire™ T180 PC Desktop
System standby or hibernating feature
To save electricity I would like to be able to use a system standby or hibernating feature . Is there such a thing on my Acer Aspire T180 PC?
That should be on all Windows Computers.
Control Panel -> Power Options.
Play with the values to your hearts content.
Posted on Oct 07, 2008
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Problems with system going to sleep. How to turn
Power options in control panel is where you can alter the settings for sleep, standby and hibernation.
Mar 30, 2010 | Western Digital My Book World Edition II 2...
When I close the laptop and reopen it, there is just a black screen and I can't get it to work. So I end up having to turn off the computer. Also when I go to the shut down from the start menu, the standby...
You probably have a sticking hibernate, or sleep button. Near the hinge, there is a tiny pin looking thing sticking up. When you shut the computer, this presses against a switch below the case and puts the computer into sleep or hibernate mode. If this sticks, it won't boot up right. Shut the computer down and use canned air to blow out at the pin opening to clear any debris.
Sep 30, 2009 | Dell Inspiron 1300 Notebook
How I can enable Hibernate and Stand By button? I have windows XP SP3
You can enable hibernation in Windows XP by following the steps below.
1. Type powercfg.cpl in the Run window. To get the Run window press Win key + R. Or, you can go to the control panel and click on Power Options.
2. Find the Hibernate tab and click on it. Check the Enable Hibernation check box. In case its necessary, free up some space on you C: drive by running disk cleanup or your favorite system cleanup utility.
3. Now you can hibernate your system by clicking on the Start button and then on the Turn Off Computer (or Turn Off ). You'll see three standard options, Standby, Turn Off And Restart.
Hold Shift key and you'll see the Standby button turns into Hibernate button. Click to hibernate (Still holding the Shift key).
4. Optionally you can do this: Create a batch file for hibernating, and put it on you desktop. Every time you need to hibernate your system, just double click this file from your desktop. To do this, First Open up Notepad, type the following line in it.
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
Then save the file as, something.bat onto your desktop. Run this batch file to hib
Or you can
manually put your computer into hibernation:
1)Open Power Options in Control Panel.
2)Click the Hibernate tab, and then select the Enable hibernate support check box.
If the Hibernate tab is not available, your computer does not support this feature.
3)Click OK to close the Power Options dialog box.
4)Click Start, and then click Shut Down. In the What do you want the computer to do drop-down list, click Hibernate.
To automatically put your computer into hibernation:
2)Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
3)Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
4)Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Thanks
Sep 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Jan 12, 2009 | IBM ThinkPad R40 2722 Notebook
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
D945GTP comes out of standby automatically
Check out all of your power options. Also make sure that none of your keys on your keyboard are stuck or mouse buttons. If anything touches yoru keyboard or mouse, it will come out of stand by.
Nov 30, 2008 | Intel D945GTP Motherboard
Boot failure pentium 4
here is a temporary fix, but you may like it as a permanent one. Use the Windows hibernate mode. It actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now. I think your system is trying to reject the power-saving features selected in Windows or at CMOS settings. Try turning off (or disabling) one feature at a time. I still think hibernate is the way to go. Here is a useful tip: to force hibernate (after it has been enabled) select START-SHUT DOWN and hover over STANDBY button and then hit the SHIFT key. The STANDBY button will turn into the HIBERNATE button. This is a quick way to enter hibernate. Remember to enable SYSTEM RESTORE mode so that if anything goes wrong during this "experiment", you can easily restore Windows system. I also use RESTORE but I also "clean house" once a month by turning it off and Disk scan and defrag and turning it back on.
Jun 24, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
Acer Aspire™ T180 PC Desktop Logo
71 people viewed this question
Brian Sullivan
Brian Sullivan
