Question about Pyramid PB70 Car Audio Amplifier
Wiring schematic for pyramid pb70
Does anybody know the wiring diagram for the pyramid pb70 in line booster
3 Suggested Answers
SOURCE: wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Posted on Jan 02, 2009
casinochip_k
SOURCE: I have a Pyramid 403G, no wiring diagram
I have the manual for the Pyramid 403G 7 band Graphic Equalizer. The wires
the wires are marked exactly the opposite of what all know as standard. According to the manual the wires marked with the black are positive, it threw me since I have been wiring for the last 25 years. If you make the mistake of wiring it like you wire everything else it will not have any power and act odd, I made that mistake.
To your radio:
Green/white left negative
Green left positive
To your radio:
Gray/white right negative
Gray right positive
Red with fuse to ignition power
Black Ground
Left Rear speakers:
Blue rear left negative
Blue/black left positive
Left Front speakers:
White/black left front positive
White left front negative
Right Rear speakers:
Brown/black right rear positive
Brown right rear negative
Right Front speaker:
Yellow/black right front positive
Yellow right front
Posted on Apr 12, 2012
danielnajer
  • 4 Answers
SOURCE: I need a wiring diagram
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Posted on Aug 08, 2012
How do I wire a Polaris PB4-60 in the USA (115V)?
if 120 volt see schematic must move the brown wire and white wire then black or colored on L1 then white on L2 then green ground to case
Jun 20, 2014 | Polaris Pb4 - 60 Booster Pump
Circuit diagram intercom
Hi Imbert, for a free wiring diagram please visit the website below and good luck Harley Davidson Wiring Diagrams and Schematics
Dec 14, 2013 | Harley Davidson Motorcycles
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
Pyramid 14G power supply
Hi.
It very unlikely the voltage went down. I think you should re measure what the voltage should be yes it 13 volt is after the bridge you wil get this with dual 6.5 volt ac from the transformer, they don't change voltage unless you have a short at the output, and if you did you will blow the transformer, is your reading from 2 wires or is it three wires, output, the center to the end should be 6.5 and end to end maybe 13.8.
I would need to see the schematic to know what voltage you should be getting.
I wouldn't look on a bat transformer but ether, bad bridge or wireing.
I hope this help's
What About Bob
Feb 10, 2008 | Audio Players & Recorders
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
Wiring a pyramid 903G
red - power
Black - Ground
Nov 16, 2007 | Pyramid 903G 10-Band Car Equalizer
Pyramid PB70 Car Audio Amplifier Logo
260 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Alan Timperley
Alan Timperley
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
