Question about Dryers
Need to know what size belt goes on whirlpool hotpoint dryer model#DLB155OBDLAD
  • 5,911 Answers
Your model number is actually "DLB1550BDLAD". The character after the second 5 is a zero, not the letter O. I'm only pointing this out to you because it is often hard to read these characters and it will avoid confusion for you in the future. The part number you need for a belt replacement is "WE12X82". You can find it at under the "Blower and Drive Assembly" heading. It is listed as item number 213. The illustrations aren't the greatest, but they may help you as well. If you do not wish to order on line, take the part number provided and go to your nearest appliance parts retailer. They should carry a stock of different dryer belts. I hope you find this information helpful. Let me know if you have further questions.
Posted on Oct 08, 2008
The belt is broken and we need a replacement for it.
Hi and welcome to FixYa, I am Kelly
Go to any of these sites and enter your model number:
If you have difficulty locating your belt I need your complete model number and will use those same sites to find your belt for you. There are 2 different sized belts for a whirlpool dryer depending upon the model number. 27 inch dryer and 29 inch dryer.
Download this manual to help you change the belt:$FILE/4322260.pdf
The order of removal is the toe panel, top and then the front panel to gain access to change the belt.
Toe panel (page 15 / pdf file page 20)
Top panel (page 14 / pdf flie page 19)
Front panel (page 19 / pdf file page 24)
Make sure you inspect the drum seals (felts) and the the drum rollers in the process of changing the belt.
The manual link I passed is for the 27 inch dryer but access is exactly the same for the larger dryer.
Thanks for choosing FixYa,
Mar 30, 2011 | Whirlpool Dryers
Hotpoint dryer dlb155obdlad will not turn. just replaced the belt.
first check to see if you can manually turn the drum ..then go to back of dryer in the center their is a cover plate...remove 2 screws to see the drum shaft ...remove the snap ring to remove the 2metal washers..and 1 fiber washer ..their should be a fiber sleave/bearing that slides onto the shaft that is in a metal bracket ...this is the rear support for the drum ..its prob.. out of bracket an grinding a big er hole ///or the front of the dryer drum slides are bad ..if you did the belt they are on top of the front panel of the dryer door they are plastic slides ..the inside of the drum has to be ontop of them to rotate ....let me know an good luck.../joe/
Aug 30, 2010 | Hotpoint NLL113EYWO Electric Dryer
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Whirlpool dryer len2000pw0, starts fine, heats up, but will not spin?
Hi, you will need to change the belt. Here is how:
Normal 0 , UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Jun 05, 2009 | Whirlpool LEN2000PW Dryer
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Dryers
2003 whirlpool dryer problems
full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
May 12, 2008 | Dryers
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Dryers Logo
120 people viewed this question
Top Dryers Experts
