Question about Kenmore Elite HE4 Electric Dryer
PF flashing, but no power failure from house elec.
Dryer shutting down, then after a few minutes of a blank screen will flash PF, although there's been no problem with the electric supply to the dryer. It will allow me to reset and start again, but will do the same thing after 20 or 30 minutes of drying. Doesn't seem to matter if I use auto cycles or manual cycles. My dad and I went thru the schematic sheets and tried to trouble shoot. We replaced the thermal fuse--but still having same problem. Will replacing the main circuit board help or not? Hate to spend so much if that's not the issue. Thanks.
  • 2 more comments
  • jonnykix Nov 10, 2008
    I have same\similar  issue with my Kenmore HE2 dryer.
    Model # 110.86562500
    I think it's about 3 years old.
    Dryer will SPORADICALLY shutdown in the middle of a load and flash PF. I simply hit power button and then turn dryer back on and all is well...then it happens again a few days later.
    I have checked all connections (it is direct wired) from Panel to dryer and all are solid. Breaker appears OK as well.
    Any assistance would be greatly appreciated.
    JN
  • TwoGC Jan 06, 2009
    We have the SAME exact problem here - help, please!
  • langdetan May 07, 2009
    Mr. Huuummm, you did not post a solution at all. All you did was advertise yourself and your fellow so-called "doctors".
  • Anonymous May 13, 2009
    This our second Kenmore HE2 and the first one was replaced one year ago with the same problem. Now the replacement is doing the same thing. We are just under the warranty time and are making the calls to get the service guy here. On the last one they replace every part in the machine before they finally lemoned it and gave us a new one. I have had the service tech her once already and he is back to scratching his head. I hate to get a 3rd one of these things and go through it again. But that may be our only recourse.
  • 750 Answers
Hello archmom03,
Welcome to fix ya,
You said,
This is a big investment if that is not the problem.
I see my customers pump lots of do it your self money into their appliances before they call me.
And I wonder why if they are so thrifty they would waste hundreds of dollars by guessing????????????
I end up being 75 dollars service call and a 25 dollar part after they spent 150 to 200 on parts them selves. This is not a calculated risk.
My good advice is save your money and let the doctor do the surgery!
God bless you Huuum
Posted on Oct 09, 2008
My Maytag double stack gas dryer does not work, the screen is blank(not lighted)
Most clothes dryers have a thermal limiter or fuse, which is a heat-sensitive safety mechanism that shuts off heat to the drum or the power supply to the dryer if it overheats. Unfortunately, you can't replace a thermal limiter once it activates. The only choice you have is to replace it; your dryer won't operate properly until you do.
Although you can't reset a thermal limiter that has been blown, you can reset the dryer's two circuit breakers and restore heat to the drum and power to the dryer. However, after the breakers are reset, you'll still only have partial function of your dryer. For example, it might spin but not heat or it might initially turn on just to shut down after a few minutes. You must replace the defective thermal limiter to reinstate your dryer's full function.
Apr 16, 2012 | Dryers
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Dryer shuts off after a few minutes clothes are cold and screen displays ad code
my frigidaire electric frontload dryer runs five in the shuts off what is the problem and where is the reset button i turned off the breaker to the 220 supply but didnt fix it and its only a year old with no warranty please help i have no money to hire a tec right no
Sep 14, 2011 | Frigidaire Electric Dryer
When I load my clothes into the dryer and turn it on it runs for approx a minute to a minute and half then shuts down and starts flashing pf on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Kenmore Elite Oasis ST 6806 Electric Dryer
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
DISPLAY SAYS "PF"
HI, there may have been a power surge that shut this unit down or, the junction box may be shorting the power sector. this will damage the main control in this case. i recommend shutting the power off by, pulling the unit plug from the wall socket or, shut the circuit breaker off. let the unit sit for 5 minutes without any power. this will reset the logic chip.
Power the unit back up after this 5 minute wait to see if the reset worked. if the PF is still present, this will confirm a main control fault. replace the control in this case.
**check the power cord junction point for worn connections.
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
PF Code on Duet Electric Dryer
just press cancel ..pf means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
291 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
