36 inch toshiba tv
Comes on and plays fine, then screen goes black, but can still here the show or movie... is this something I can fix.
    Scholar:
  • 142 Answers
You have most likely turned on closed captioning by accident. Well, hopefully!! Go into the menu and make sure closed captions are turned off. Good luck!
barneyluc
Posted on Oct 10, 2008
I have a 32 inch RCA LCD TV. when I play a movie, every 2=3 minutes to goes back to the blue screen, and blinks a few times then goes back to the movie. Its with every movie and I dont think it is my dvd...
Probably the Controller unit for the TV. Try hooking it up through a different connection type e.g. HDMI, component. See if that fixes the issue for the time being. If it dies then those ports you used previously are malfunctioning.
Mar 19, 2011 | Televison & Video
I have a 36 inch toshiba tv model # 36A50 and i have black bar at the top and one at the bottom i only have approximently 3 or 4 inches of screen in the middle to watch. what would it be? that problem...
For one thing you have a vertical problem and since it got that way gradually you can bet that there is a bad capacitor in the vert. circuit(pump-up cap) as far as the price goes it depends on your local servicemen, i`m in canada and that sort of problem fixed at home would run around a 100.00$. good luck
Nov 02, 2009 | Toshiba 36A40 36" TV
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Toshiba TV Red Color turns black and regains after a long time
If this is a crt type, it could be a loose connection. Check its RGB board usually located at the backend of the crt tube. Dust, cobweb, carbon built up might be the one causing it.
Apr 12, 2009 | Toshiba 36AF41 36" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Fixing BD movie disk on UK Ps3
Try a Blue Ray lense cleaner dont where to get
Sep 15, 2008 | Sony Playstation 3 (PS3) Console
Toshiba 36 inch TV (8 Years Old)
If the shrinkage is just the top & bottom then it is relatively easy/low cost fix. Most probably, a capacitor in the vertical section is nearing end of its life. This would be the biggest of the bunch and would be something like 47uF/50V.
If however, the shrinkage is on all four sides, then it is the master power supply that is at fault. Chances are the main B+ is getting low which cold be caused by the big filter capacitor or an erratic regulator. This is not a simple fix and would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
