Simpson enduro washing machine 701 keeps filling even when set on low . also when lid open doesn't stop water straight away , when stop or power turned off doesn't stop water straight away 20 secs
  • 943 Answers
HI thanks for the question. I would replace the water valve . this is a sign of a faulty valve. thanks . rate my answer please
Posted on Oct 07, 2008
My Simpson ezi sett 7.5 always fills to full even when set to low. i have replaced the pressure switch and still fills to full.
Check the rubber hose from the pressure switch down to the bowl for any holes or splits allowing the air pressure to escape. Also check that water valve is stopping the flow. Start to fill then press pause. Water flow should stop immediately. If it keeps flowing or is slow to stop then replace the inlet valve. Try it several times to be sure.
Dec 18, 2016 | Simpson Washing Machines
Need to open and close lid 3 to 4 times before machine starts to fill using only cold water have tried with hot same thing if second load put in after first straight away fills as normal
check the lid safety switch for proper adjustment
the unbalance lever works the same switch so in an unbalanced situation the switch may have moved of the lid setting a bit
Nov 21, 2016 | Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
I have a Simpson 22S750M 7.5kg eco washing machine problem is that it doesn't drain the water on the last cycle as it thinks that the lid is not closed even though it is, the beeping is driving me nuts...
we have had the same machine for a few weeks and have the SAME exact problem. They are replacing the whole electronics board but the part has to come from SA and will take a week at least. I have an incont child and this is very hard! why dont they recall?
Sep 18, 2009 | Washing Machines
Washing Machine won't stop filling and then won't stop emptying
Does your machine fill with water even if the machine is off? In this case your inlet valve at top of machine is defective & can be easily replaced (will tell u where to get spares, if your dealer cannot) by yourself.
If water does not stop, after filling machine at a low level(is this a front loader?) and is flowing away - check your exit pipe, it has to have a certain height (approx 3 feet) up before going down to your drain pipe.
Feb 24, 2009 | Washing Machines
Simpson enduro 701 very slow to fill and timer sticks
Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
Joyce
Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
292 people viewed this question
Top Washing Machines Experts
