Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
Take off freezer door
I'm moving and i need to take off the doors to the refrigerator i got the top henge off and i need to know how to take the bottom henge off there is a white tube with a spring and a gray piece how do i take that piece off
Why don't you just take off the handles? That is what we did and it worked just fine.
Posted on Nov 12, 2008
How to raise freezer door on Kenmore 18.2 cu. ft. Top-Freezer Refrigerator for better seal
Adding spacers to the hinge pivot is about all you can do. Check to see if the door closing cam is in good shape it could be too worn or broken this will cause the door to drop. Sometimes loosening the upper door hinge and moving the door sideways can raisie the door some.
Aug 13, 2014 | Refrigerators
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing
Apr 16, 2011 | Whirlpool Refrigerators
Leak at the top of seal
use a hot cloth to mould the seal back into place,once bent to shape it will stay that way.
May 21, 2010 | Whirlpool GB2SHDXP Bottom Freezer...
GE side by side doors are not alligned
here is a diagram of the doors and the hinge area. Without seeing myself I can only gusess.
you box could be twiked or not level. The hinge at the bottom could be bent. There top hinge sometimes can have an ajustment that moves the top of the door left and right wich will raise the door a littel. to see if this has an ajustment you will need to remove the top cover of the top hinge and loosen the bolts a little and move the door left and right, if it does have someone hold the door where you want and tighten.
Jan 11, 2010 | GE GSS22SGM Side by Side Refrigerator
Changing the opening side of the door
You will need to reverse the hinges, it should be the top for the freezer, and the one in the middle support, both the freezer and the large door, you will not only move this to the other side but you may have to turn it over, and the bottom hinge just move it to the other side. You will need to start with the large door, because the hinge support the bottom and top door, the bottom first, next the middle hinge, place the freezer door on the middle hinge and the top hinge to sesure the freezer door, move the handles, the holes for the screws will be on the other side with a little cover that you will have to remove just have to pull them out.
Nov 25, 2009 | Maytag MTB1891AR Top Freezer Refrigerator
My refrigerator door says Er FF
get some oil and put it on the henges.or maybe it ca be rusting or maybe people slam the refrigerator to much or hang on the door
Oct 28, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Model TFA27R doors out of alignment; top of refrigerator door must be moved to right as it rubs against freezer door at top. How do I adjust doors?
Slotted screw on top of door, under a cover, needs to be loosened, adjust the door, tighten. That's it.
Jun 22, 2009 | GE Refrigerators
Bottom freezer door moves top to bottom by moving handle in & out
Hi, most models have adjustment screws near the track connected to the door if this is a slide out door. If this is a swing out door, you might be able to twist the door back in shape.
If the gap is only in the corner of the door, try inserting a piece of paper towl rolled/folded up behind the gasket to help stretch it.
I hope this helps you. Please let me know if I can assist you further.
Jun 05, 2009 | LG LRBC22544 Stainless Steel Bottom...
I have a new 2007 Roper Refrigerator with a top freezer. The door of the refrigerator does not shut correctly. I can see the light when I look between the freezer door and refrigerator door. If I lift and...
Generally speaking. Refrigerator door are assembled from bottom to top. Remove the cover on the top hinge of the freezer door. Remove the top hinge and lift the door to remove. You will now see the top hinge for the refrigerator door. This should be adjustable by loosening the screws and move it toward the outer edge of the refrigerator side. Tighten the screws and lock it in place. Reassemble the freezer door in the reverse order that you removed it. That should take care of the problem.
You can observe the top edge of the refrigerator door in the closed position when you have the freezer door removed.
Jul 31, 2008 | Roper Refrigerators
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
104 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
