Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine power button won't turn the machine on
I just washed a load of laundry and the machine worked fine. Beeped to let me know the load was finished. I put in a new load, pushed the "control on" button. Nothing happens. No lights, nothing. I checked the power cord and it is plugged in and has power. I have held the button down. Nothing. I held the control lock button down and a light comes on to let me know the controls are locked, so the machine defintely is connected to the power source. Help!
  • Tina Tishendorf
    Tina Tishendorf Oct 08, 2008
    We found that the ribbon like wire that runs from the main computerin the back to the front dial was rubbed against the barrel from the spin cycle and caused the copper wire to split in two. We rewired by bypassing and it works fine now.
  • yramesknab Oct 08, 2008
    the controls locked button is lit but nothing else will work
    Problem Solver:
  • 10 Answers
Defective timmer
Posted on Oct 08, 2008
Samsung j1045 washing machine
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Oct 14, 2012 | Samsung Front Load Washer Control Board...
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't start, just beeps three times for any function now
Make sure the door switch doesn't appear to be broken. I believe there should be a little button right above the square hole.
Apr 23, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool LTG6234DQ Stopped Now Won't do anything
a sink stopper will not damage your unit its to big,,it cant get though your wash basket...check your outlet,,or use another out rated 15 amps or more..
Nov 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Door locked
f 22 is the code for door Lock failed after six tries try hitting pause/cancel twice if door unlocks spray lock with wd 40 try again and advise
Dec 29, 2007 | Whirlpool WFW8500SR
Whirlpool Duet GHW9150P Front Load Washer Logo
676 people viewed this question
Dan Webster
Dan Webster
Sal De
