Question about HP Computers & Internet
Upgraded Z558 to Vista, playback and tv appears to be sluggish to the point video is off from audio
  • 749 Answers
Make sure you update the video driver to a Vista driver if you have move from XP to VISTA
If not loaded, vista will load it's own default generic driver and you will notice a bite in performance.
Posted on Oct 07, 2008
LG GP40NB40
Are you connecting the unit to your computer or a TV?
If it's the former, what OS does your computer have? Can you access the DVD to read the contents of any optical disc or play back audio CDs? If you can't get any content, then try a different Y USB cable (shorter cables are best). If you still don't get a response, try a different optical drive. The LG GP40NB40 may be faulty. If it is under warranty (1 year), contact LG or return it to the store where you purchased it (usually a 30 day return period).
If you have Windows 8, it doesn't come with the Codecs to play DVDs. (Some new Windows 8 machines will include a program like Cyberlink's PowerDVD. However, not all will.) In that case you need to install an appropriate program to play DVDs. The Win8 Media Player requires an upgrade to Win8 Pro and then the purchase of the Media Center. VLC will play most DVDs http://www.videolan.org/vlc/index.html . Some DRM issues may interfere. There are other DVD playback programs you can try. (As far as I can tell, the software that LG included with this model is not Win8 compatible for playback of movies.) If you had an older version of Windows and upgraded to Windows 8 Pro, you just need to purchase Media Center. (At least with some machines, the DVD playback software before the upgrade wasn't Win8 compatible and has to be upgraded.)
If you have a different OS, please indicate which one. (XP, Vista and Windows 7 all came with media player codecs for DVDs. Before that, the feature wasn't included.)
If you are connecting to a TV, it isn't designed to play commercial movies. It acts like a flash drive to play videos, display photos, etc. (Thus the limitations are due to the TVs file Codecs. Check the TV documentation.)
I hope this helps.
May 19, 2013 | LG GP Computers & Internet
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
I have a GVA TV (G32FHDLCD2) and want to use the USB port but its not recognising anything. The instructions say this is for "upgrade only". What does this mean and how do I use the USB...
It means the usb port is only for upgrading the TV's software & not to be used for any other purpose. Please check your user manual for usb compatibility for audio & video playback.
sonsunny
Jun 17, 2011 | Televison & Video
I have the above model camcorder ,the playback on my laptop with windows vista is terribly poor jumping all the time/distorted with jvc software provided or on windows media player it plays but audio is...
Are you playing the video directly form the hard disk in the camcorder or are you transferring the file to the laptop first? Reading high volumes of data via USB is slow and the PC may not be able to read the data fast enough from the camcorder. Try copying the video to the laptop first, then play it back.
Feb 20, 2011 | JVC Everio GZHD500 High Definition AVCHD...
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Cpu upgrade for Winfast n15235 currently AMD 3600+ 2.0ghz, GSA h40n opitical drive , 750g WD,ROXIO 2009 Cineplayer,Realtek HD audio,nVidia 7200 , Vista occasional stop...
To be quite honest you do not need all that for watching a good quality movie! Your processor is good enough! As long as you got a nice upgrade on your video card and sound! A nice Player and enough Ram you will have great video playback.... I hope this helps you decide.. Good luck to you!
Oct 17, 2009 | Computers & Internet
Random HDMI audio and video drop out & video noise
Hello, I am sorry about your issue. I suggest that your receiver be looked at by a service center. Thank you. Onkyo USA
Apr 03, 2017 | Onkyo TX-SR606 Receiver
Sluggish audio and video
you may need a ram upgrade. how much ram are you using?
also you may need a graphics upgrade. then it should play fine.
Feb 25, 2009 | HP LightScribe dvd640i (DVD640I)...
INPORT Installed, Sound Disappears
The Xitel site http://www.xitel.com/USA/support_inport.htm says when this happens, " 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback."
Jul 20, 2008 | Xitel INport (HFLI1X1) Audio Input
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
