Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve 8300 Camera Problems
My Blackberry Curve 8300 could not start the camera. It is saying I should close other applications and try opening the application again but itstill will not work. Any other suggestions? I have restarted my phone after waiting 30 seconds and I have gone through the whole holding of the "alt key and pressing the back key to view the other applications but none of those work."
  • 1 more comment
  • ahsietal Oct 08, 2008
    I am getting the same response so I dont know ........
  • Anonymous Feb 11, 2009
    Same problem. I have a memory card and removed it and then put it back in. Same problem each way. Haven't tried to wipe it yet.
  • Anonymous Feb 26, 2009
    When trying to start my camera it says that the "Camera could not be started close other applications and try opening the camera again"
    Just spoke to AT&T. She talked to tech support who says that it is the device itself and not a software glitch. I was told that I have the option to use the insurance. In essence pay 150 for a new Blackberry that is now like 50.00 or since I was eligible for an upgrade I can upgrade my phone to a new one. What happens when you are not eligible for the upgrade? You have to pay a lot of money I say great customer service AT&T. Im thinking about switching to another service provider.
After reading many posts, I removed the back and and pulled out the battery, then removed the memory card and blew air all over it, put it back together in reverse order, and works like new.
Posted on Jan 19, 2010
    Sniper:
  • 84 Answers
The two solutions to this issue are to add a micro SD/SDHC memory card to the device, or to wipe the device (after prefoming a backup in Desktop Manager) to see if that works.
To wipe the device you will go to Options > Security Options > General Settings. Press the menu key, then select wipe handheld.
Posted on Oct 07, 2008
  • J Kitch
    J Kitch Oct 08, 2008
    If these two options haven't worked, then the final thing to do is actually delete the entire operating system and reload it from scratch. There is a program called JL_Cmder that allows you to completely erase the operating system and data and programs. Check out the two links below:
    Wipe operating system with JL_Cmder:http://blackberryfaq.com/index.php/How_d...
    Install new BlackBerry operating system:http://crackberry.com/blackberry-101-how...
  • Trevor Mccloskey
    Trevor Mccloskey Jul 29, 2012
    that dont work either
I had the same error poping up everytime i openned my camera on my bb curve 8330 and only thing i did was take the battery and micro sd card out and blowed on the battery terminal and sd terminal and a little hole by the side of the camera and put evrything back in and now my camera works just fine
Posted on Jun 19, 2010
    Problem Solver:
  • 9 Answers
YOU HAVE OPEN THE DEVICE AND REMOVE THE CAMERA AND CLEAN THE CONTAC POINTS THEN PUT IT BACK TOGETHERE WORKS FOR ME.
Posted on Jul 08, 2009
None of the things people are telling you work all you can do is if you have warranty still you can get a new one if you don't you can pay $19.00 to get it thats what AT&T told me and same when I had t mobile.
Posted on Feb 21, 2009
I had the same problem. After deleting all pictures and a game.I thought that would help. I ended up just taking the battery out and putting it back in, it worked but it took about 5 minutes to restart.
Posted on Feb 06, 2009
Camera not warking
Posted on Aug 17, 2012
  • I had also the same problem with BB8300 camera "close some apps & try again" but no solution available ,even memory card also not working ! plz send me the proper solution H_vcs@yahoo.com
Posted on Apr 24, 2012
I just got the blackberry curve 8330 from a friend who got a new phone and i kept having a problem where it said could not open camera other apps are open and nothing was open so i tried everything and nothing would work but then finally i tried the simpleist thing which was take the battery out and put it back in with out touching anything else. Good Luck! i was really mad when it didnt work
Posted on Aug 28, 2009
I was getting this same error for a very long time. I finally gave up, then today was searching how to repair camera. I took my phone apart using a T-5 driver, and used a air blower and blowed the entire inside of the camera, front and back. Put back together, was about to wipe it clean using the Jl_Cmder, but for the hell of it, tried the camera once more, and was amazed that it worked like it never went bad. Not sure if it will work for everyone, but it sure did for me.
GOOD LUCK, i am happy as can be!!!!
Posted on Jan 05, 2009
Could not start the camera. close other applications and try opening the camera agai
why is my camera not working, it is saying close other applications and try again.
Feb 05, 2011 | AT&T Blackberry Curve 8300 Smartphone
Camera ERROR MESSAGE Blackberry Curve (Sprint)
Your OS maybe corrupted so you will need to reinstall the OS, you can do this by connecting the phone to your pc/laptop using the USb cable then open the Blackberry Desktop Manager and click on the apploader then install the applications and install the OS as well as the features for the phone....
Thks
Bajan Guru
Barbados4life
Dec 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
My camera on my blackberry says the same thing
this just happened to me--I took the battery out for 5 minutes, put it back in (the hour glass was spinning for a LONG time) and when the phone turned back on, the camera worked. try this before all the other suggestinos.
Jun 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
How do i reset blackberry curve 8330 to factory settings
are you actually going to the menu button and selecting close on each screen or just hitting end or the return button to get to the home screen? If you don't actually select close in the menu screen some progams remain open. go into all applications when there press the menu key and scroll down to close this should help
Jan 17, 2009 | RIM Blackberry Curve 8300
Camera on blackberry 8320
I have the same problem...But the thing is I bought it from eBay. Can someone help me too?
Dec 10, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry camera
turn off ur bb mobile by disconnection the battery from mobile phone and put the battery after 1 min and start the hand set
Nov 16, 2008 | AT&T Blackberry Curve 8300 Smartphone
Camera wont start!
Wipe operating system with JL_Cmder: http://blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
Install new BlackBerry operating system: http://crackberry.com/blackberry-101-how-install-or-upgrade-new-rim-operating-system-os
Sep 29, 2008 | AT&T Blackberry Curve 8300 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
7,752 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
