Question about Hobart Food Mixers
Hobart V1401 Shaft Broken
We have a 3 year old Hobart Mixer that an employee was using and the shaft broke in half. I was wondering if there is any way that the shaft could have broken other than operator error such as not tightning down the bowl or installing the hook incorrectly?
I'd advise that you contact your local Hobart Service Branch for guidance on that question. Please visit the service website at www.hobartservice.com and click on 'Locate an Office" - you'll be able to locate the closest Service Branch to you for advice. Hobart does also sell replacement parts to end users direct as well - through the local Service Branch.
thanks
Sherri Wilmoth
Hobart Marketing
Posted on Oct 14, 2008
Most problems occur with borken shafts are do to customers overloading the bowl with product.I recommend going to hobartservice.com and printing a mixer capacity chart for your model machine and pay close attention to the absortion ratio portion at the bottom of the chart. If any problem understanidng it call your local Hobart office and they can help you over the phone . steve
Posted on Dec 04, 2008
Have a broken shaft on a 20 qrt Hobart mixer that snapped at the bottom.what part do I need
a new shaft to replace the broken one
get it from Hobart spares for the model
Aug 19, 2017 | Hobart Food Mixers
HOW DO I MANUALLY LOWER BOWL IF MIXER WILL NOT START?
Trina you might be better off to contact Hobart or an authorised Hobart service agent about this. The lack of answers probably indicates resident hobart experts are absent.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
I've broken the agitator shaft pin on my Hobart A200T. I can find replacement pins online, but the local Hobart tech. is MIA. How do you remove the pin? How do you secure the replacement in the...
Drive it out with a punch and hammer. It's best to take the planetary off the machine so you can support the shaft. If not it puts a lot of unnecessary stress on the bearings and other parts.
Jul 08, 2011 | Hobart A200 Stand Mixer
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
I just bought an old Hobart mixer....All the
www.hobartservice.com enter your zip in "locate an office" it will bring up your local Hobart office.
May 16, 2010 | Hobart D300 Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Hobart A200 diagnosis
the first A-200's have a worm gear drive that will slip when old but also when mixing dough somtimes the dough will push the mixer aherad of its self and look like its slowing but its just catching up. if you have a old worm shaft it will have a spring on it is how to tell. it is replaced with a shaft that is all keyed and has no slip or give unless a key shears.
Michael
Nov 25, 2008 | Hobart A200 Stand Mixer
Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
Jan 11, 2008 | Hobart A200 Stand Mixer
Dough mixer not working at all
it sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Oct 27, 2007 | Hobart D300 Stand Mixer
Food Mixers Logo
366 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
