Question about Canon IMAGERUNNER 6570 Copier
Canon PC-6re copies are all black
After cleaning the dust proof glass and the corona wire the printer still prints pages gray black. The copy material does not show on the copies.
  • dbquirk Jan 29, 2009
    Yes, I have the same problem.
    All copies are all black, the whole bage is black.
    Well, what can I do to fit this?
    I don't see a solution here.
    DQ in NJ.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
1-the scanning lamp is not coming on
2-seperation is not working properly
3-the HVT for the seperation is not working
Posted on Oct 08, 2008
  • 3 more comments
  • nancy
    nancy Nov 17, 2013
    How do I fix the scanning lamp?
  • CheckitRight
    CheckitRight Nov 18, 2013
    1--make a copy-- does the lamp where paper is laid on glass turn on? no replae -- yes -- step2
  • CheckitRight
    Seperation --coronas under the drum are Arcing -- replace - (if it's sponge roller type) clean by gently rubbing w dry cloth--
  • CheckitRight
    Scanning lamp can have 2 problems 1 the lamp itself which you will have to order and replace / its held in pace by copper end tension -- push on one side and it will release this is delicate --2 --diode looks like a resistor I would order both held in by srews.
  • Santosh Pattnaik Aug 15, 2016
    First remove the copy board glass
    then Clean the scanner reflectors(mirrors) with dry and soft clothes
My minolta ep4000 copy machine print the pages black why?
Clean the optic sisitem componenets,mirrors(4 mirrors),lens,original glass,clean the erase lamp obturation filter(located in OPC drum area,clean the drum charge corona unit(wire,grid).
Mar 09, 2013 | Minolta EP4000/5000 CS/PRO Copier
When I try to copy a letter or anything, a black line shows up down the center of the printed copy. How do I remove this?
look at the scanner glass. It probably has some dust specs on it, clean it . Also clean the small glass toward the left of the scanner glass. If the dust specs are under the small glass, you can carefully remove the glass and clean it.
Jun 28, 2011 | HP Photosmart Premium C309A All-In-One...
When printing, there is a black stripe on the right side of the page. What is causeing this?
If the problem appears when printing a page from the computer, it is most likely a bad drum unit in the machine. The only way to fix this is to replace the drum unit itself. On your model, I believe the drum is part of the toner cartridge.
If the problem appears when you make a copy by placing your original in the feeder but not when printing from the computer, then the problem is dirty optics. The next step in troubleshooting the problem is to make a copy off the glass, bypassing the feeder. If the line is still there, you will have to open up the optics and clean it from the inside. If the problem goes away, there may be something on the "**** glass" of the machine.
The "**** glass" is a small strip of glass to the side of the main piece of glass that you lay your copies on. It will be a strip that is separated from the rest of the glass, and is about 9 inches long by about an inch wide. This should be cleaned really well to insure good copies. Do NOT spray glass cleaner directly onto the glass, as it will run under the glass and cause more problems. Use a high quality lint free towel and spray the cleaner onto the towel. Believe it or not, an old T-Shirt is excellent for this.
I would suggest cleaning all of the glass on the printer on a fairly regular basis, depending on your usage levels. For most home office users, this would be about once a month, for professional usage in a normal office environment, I would clean it about once a week.
Feb 28, 2011 | Brother MFC-7340 All-In-One Laser Printer
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Lighter bands across copy using Canon F 132500 copier
Open the flap to expose copy platen and press print you should get a flat even black
if you get the white bands do the following:
Clean the corona wires open the cover pull out the sliding charge wires and clean with q tio and acoho or a pencil erasure
If that does not work remove top glass and clean mirror and bottom of glass
Dec 24, 2008 | Office Equipment & Supplies
Printer problem
Does the line appear while copying or printing ?
To isolate the issue try to print a self test page :
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
If you see lines on the test page then the issue is with the cartridge or cartridge contacts. Clean the cartridge and cartridge contacts inside the printer.
rRemove both the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth. Gently wipe the contacts, from the top to the bottom.
Reinsert the cartridge and print. If the issue issue persists replace cartridge(s).
If you do not see lines on the test page. Place the same test page on the scanner glass and make a color copy. If the lines are on the copied Image the issue is with the scanner glass.
clean the scanner glass :
Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service or contact HP for in warranty replacement.
Thank you .
Silan
Dec 20, 2007 | HP Photosmart C3180 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
522 people viewed this question
old marine
old marine
