Question about Compaq Presario R3000Z Notebook
Hibernate cant find hibernate - laptop used to have hibernate function when i went into shut down options, now it doesnt have it. how can i make my laptop hibernate again? its vista
  • Anonymous Apr 11, 2009
    hp pavillion dv6000
  • 41 Answers
Try this
1. Click Start , type command in the Start Search box, right-click Command Prompt in the Programs list, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue
2.At the command prompt, type powercfg /hibernate on.
Posted on Oct 07, 2008
Cant switch off!
Pull the AC plug, remove the battery. You didn't post the Make, model of Laptop or the OS you are using? Reboot, open Control Panel, select Power Options, select High Performance, open Advanced Power settings/Change power plan, Set Hibernate and Sleep to Never, set advanced power settings to your preference, always shut down and unplug when not in use. Remove battery when using on AC power for extended periods.
Mar 13, 2013 | Computers & Internet
Tip
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 | Computers & Internet
My computer still functioning even its shutdown already
have you tried to hold the power button down for 5 seconds? if that doesn't work, it's possible that when you click the shut down the last option used was the hibernate option. when you click the orb click the arrow pointing to the right next to the power indicator and make sure it's set to shut down and not hibernate
Aug 02, 2012 | Lenovo Computers & Internet
Toshiba terra went into hibernation and will not boot
I find extensive use of the hibernation eventually corrupts window files until it will not start. The best option now is reload your operational system for a fresh install and disable this function, select power options and click hibernate "top right" and make sure box is unchecked, if not! uncheck and click apply and okay.
Mar 22, 2012 | Toshiba Computers & Internet
I have a Thinkpad t60. For the past few days it won't go into hiberation when I close the lid. It just stays on and consumes the battery.
I have seen this issue before with my T60. It seemed to be related to not having restarted my laptop in a while. I used to use hibernate rather than shutting down my laptop for weeks at a time. Actually restarting my laptop seemed to get hibernate to work again.
In addition, you can check to see if for some reason the hibernate option has been disabled.
In Win XP (Win 7 is very similar):
  1. Click Start and select Control Panel.
  2. Double-click Power Options.
  3. On the Hibernate Tab, ensure Enable hibernation is selected (check mark).
  4. On the Advanced Tab, ensure that the setting for When I close the Lid is set to Hibernate (select it from the drop-down list if necessary). There should be an option for when plugged in and when on battery. Set both to your preference.
Hope this helps. Thanks for using FixYa.com
Jan 18, 2010 | Lenovo Thinkpad T60 Notebook
My acer mininotebooks goes on hibernating
check to see if your power cable is bad. if it went bad your computer would go to hibernate to save energy, then shut down all together. see if when you plug in your power cable if your computer shows that its charging. if it does maybe its a bad battery.
Jul 13, 2009 | Acer Aspire 5100-5022 Notebook
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
My hp 530 laptop with windows vista doesn't sleep or hibernate
Sleep/hibernate is a function of the video driver. so download and install the latest video driver from hp.com
Dec 13, 2008 | Computers & Internet
Hibernate
Laptops have a ACPI power management piece of hardware on the motherboard. Sounds like this driver is corrupt or missing. Go to Acers website and look for drivers and find the one that says ACPI or even chipset drivers may have it.
Nov 02, 2008 | Acer Aspire 5610-4648 Notebook
Compaq Presario R3000Z Notebook Logo
184 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
