Question about LG MZ-42PZ14 42 in. Plasma Television
LG 42PX4RV went blank
Hi, i was watching the TV and all of a sudden the TV went blank, saound is there as normal for all channels but no TV, can not view the menu options either, plse advise
  • tores12 Jan 11, 2009
    Hi, I have a lg 42px4rv model plasma tv. I have a problem, in fact when appear a black image in the monitor i have blue green and red pixel that are pulsing in the black. Pratically the black image, after a white image, have some problem to turn back. Do you have some Idea to resolve the problem?
  • LG Master
  • 5,568 Answers
Plasma sets have a little in common with th eolder CRT sets in that they use much higher voltages than LCD sets do except in the circuit powering the backlight.
If it is affecting video only, the display's power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for two separate boards with mostly larger components on them; they will have ferrite core transformers on them and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on either board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
The section most likely to fail and cause your problem will be one that you see associated more with the display than the incoming AC line; the latter is the main power supply and its failure would result in no sound or video.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 07, 2008
LG 32LB9D lost channels
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 16, 2017 | LG 32LB9D TV
While watching the TV the screen went blank and there wasn't any sound. I've checked all the cables. I tried turning it off and back on but when I did this the power light flashes 27 times before...
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 28, 2011 | LG 32LC2R 32 in. HD-Ready LCD Television
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
MY LG LCD TV PICTURE DIED
Hi...there,
Wow! You guys...must had watching a really....HOt sizzling movie to make it overheating. Hehehe...
Your inverter are fried, need to replaced a new one. If you still under warranties asked LG to send you a replacement. Have a nice weekend!
Oct 04, 2008 | LG Flatron L1710S 17" LCD Monitor
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG MZ-42PZ14 42 in. Plasma Television Logo
422 people viewed this question
Computer Repairing
Computer Repairing
