Question about Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation
KM-450MAB making beaping noise-compressor will not run
My ice machine is making a beaping noise. When the cleaning valve is open the noise goes away but the compressor will not operate. The manual says the valve must be in the closed position in the ice making mode.
  • amimichele Oct 22, 2008
    Wow! Same problem, did we get them from the same guy?
  • tdarty Oct 25, 2008
    i hear 3 beeps and so i cleaned the filter checked out the condenser . i reset the the reset button and the beeps went away i dont hear the compressor comeing on
  • 51 Answers
The cleaning valve must be closed duing the ice making mode. If it is open, the machine will not make ice. The beeping you hear is the alarm which is present on the machine. Remove the front cover and read the included text. This will tell you what alarm you have.
Posted on Feb 20, 2009
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model km 900mwh low side suction line has ice building up on it all the way to the compressor
Is it making ice? Frost on this line is not that uncommon as it is colder than the air around it. Make sure you have good water flow over the evap plates. machine may just need a good chemical cleaning.
Jun 14, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Unit makes ice,full evaporator,is very slow,maybe 45 mins. from harvest to harvest. Why so slow?
Possible causes are many
Things to check
  • If air cooled, is the condenser coil clean and is the condenser fan running when in ice production ? Is the area extremely hot where the ice machine is located? If water cooled, is there adequate water pressure and is the water regulating valve set properly?
  • When the system switch is in the off position is there any water running ( if so the inlet water valve may be stuck open)
  • When in ice production, is the small tube that feeds from the hot gas solenoid hot? This tube comes from a valve at the back of the unit and feeds over the compressor and into a tee near the insulated Tx valve. This line should be hot during harvest and cool shortly after harvest.
  • Has the float switch assembly been cleaned. this is a cylindrical unit beside the water pump,It can get plugged with minerals and not initiate harvest
  • The system may have a refrigerant charge problem (short) or the compressor may be weak, at which point diagnosis would need to be done by a refrigeration tech
Hope this helps
Oct 29, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-450MAB water runs constantly even on freeze cycle. Water is very cold.
Hoshizaki machines have a water inlet valve that can stick in the open position. This will cause the machine to do silly things. If you can turn the machine off and you can still hear water running, the valve is stuck open. It is an easy fix. Water valve only has 2 wires going to it and 2 water lines. One inlet and one outlet. Just turn off water and kill power at the breaker before doing any work.
Hope this helps and good luck.
Try Rick and Restaurant Parts and More in Ohio for a replacement valve. 1-888-814-1110
Apr 01, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
207 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
