Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
No geen colour!but great pic and sound
Can anyone help i have a three year old sony kp-46wt520 rear projection tv.. last week the tv started to loose its green colour now the picture is still great but the football pitch is more bluer than green......a local tv man came out and said its the mother board and cost would be about$1000........... he new this by just turning it on and changing channels it did take him 30 seconds for his expert view...is there anything i can try before i bin the tv as i will not be paying that much for it to be fixed.
many thanks'
martin
  • 2 more comments
  • marathonmart Oct 09, 2008
    when i look in the rear of the tv the only control that i see is a wing nut on the green colour light which slides up and down .. when i loosen the nut and slide it up the image go,s off and the green colour halos peoples heads and objects on the tv....i do not see any black box on the front grill part with 6 little knobs on?
    i have clean the lens of the now very bright green blub but no change the grass is stll bluer than green...any thing other i can try?
    many thanks
    martin
  • marathonmart Oct 14, 2008
    thanks for all the info..
    i have now tried all the things you told me to do but with no real change..i take it there must be some kind of chip that may have fried.. is this a easy fix ...after i have tried to locate the problem that is...
    many thanks again
    marty
    hi
    with a blank video channel
    i turned the bottom middle screw to the point were i started to see green lines on the black sceen,then i adjusted black to the point that i could not see them...
    when turning back to a tv channel the green was no better and there was a slight retrace line around objects so i turn it down a little more...
    i will now check the video output chip for this colour..
    ? why is it when i change channels the colour of the channel number comes up on the screen in a great colour of green...
    thanks
    marty
  • Anonymous Nov 03, 2008
    green colour problem everything else seems to be ok
That's good news.. your display shows green which meens your green crt is working so the only other way to tackle this is in the service menu -your drives and cutoff's. you get there by starting with a set in standby next using the remote press buttons 1 after the other "display"- "5" "volume+" -"power"
the set will come on and you should see green writing top left. again using the remote...you need to scroll through the long list of settings pressing button "1" as in channel button 1 to advance the list use button 4 to decrease when you arrive at g cutoff you can use the 3 button or the 6 button to get the color you want also try the g drive again using the 1+4 buttons to get there and the 3+6 buttons to adjust once you have the right color write it into memory pressing in sequence "muting " then "enter"
you will see the display color change if you are doing it right, then you can power down the set and turn it back on again to see your resulting adjustment changes, repeat proceedure if needed.
don't adjust what you don't know about save yourself some grief
later
Posted on Oct 15, 2008
  • 185 Answers
Sure turn up your screen control for that color slowly if color comes back then the adjustor is just dirty (no repairable) make sure you don't see milky white lines or a solid color on a blank input.
put the unit on a video position that has no source so the tv displays the input label but nothing else.
slowly adjust the screen control( behind the front grille little black box with 6 little knobs on it)
untill you start to see the coresponding color then back it off till the color is gone, you are done.
if this doesn't work then check your video path from jungle to crt output, your output chip may ne fried
Posted on Oct 08, 2008
  • A Schneider Oct 10, 2008
    you should never move that yoke on the crt (tube) as it will throw your alignment out. carefully position that yoke back where it was.... you can use the other 2 as a reference match the 1 to the other 2 using a pattern that i still. the control u want is behind the front grille . after you remove the grille you must remove the black panel just below the screen. after you do that you will see a small epoxy box about 3 inchs square with 6 little adjusters on it. look closley for the the 1 adjuster in the middle at the bottom that will be your screen control,follow the instructions given before.
    this can shift over time, so you may have to readjust in 6 months or even sooner. this is a defect
    that you might be able to live. sony replaced all three tubes under warranty when it was in warranty
    causing a serious shortage of replacement tubes for those tv's. as far as iv'e heard there are no replacement tubes to be had. watch for it going to a solid color in the future our even a slight change in hue, this is the indicator that an adjustment maybe needed... if you do see the screen go to all 1 color turn the set off as this will kill the video i.c. make a mental note as to what color it was then adjust the color screen control counter clockwise a 1/4 turn before turning the set back on. at which time you can adjust the control again to obtain the correct color balance.
    cheers
  • A Schneider Oct 14, 2008
    are you sure you adjusted the right color as mentioned? if the tube has voltage on it then the screen adjuster will make the beam in the tube increase, keeping inmind that the auto kine bias will try to back off your adjustment as you are doing it up untill a point where you will see retrace lines in the picture with the color being predominent don't leave the tube biased with retrace lines. back off the screen control untill the color fades correct color balance will be had at this point. if indeed this doesn't correct it or there is no color change then check to see if the crt has the 225 volts going to it.
    chances are it does as your other tubes are sharing the supply, if it checks ok then the video output chip is not working it is on the crt board plugged into the end of the tube it's a tda # as i recall and they are cheep. also look for the small resistors around the chip, check for the right ohmage there.
    always unplug the unit before doing anything and wait for any voltages to drain off about 5 min.
    also if the tube is non funcioning then the tube itself may have a charge on it be carefull, the flyback might not have drained it off. never short this to ground, a high voltage probe will let you drain these tubes off safley
    cheers
Led stand by light blinking
No power supply proble Google to Encompass Parts Distribution and type in your model number.
Jun 01, 2010 | Sony KP-46WT520 46" Rear Projection...
NO SOUND AUDIO
Just to be sure, it isn't on SAP is it?
That would be under the MTS/SAP button.
If that's not it, are there any other distinguishing features that you notice?- A buzzing or a clicking or peculiar light flashing?
I wouldn't be able to help with that, but the next person might!
May 08, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Light flashes 9 times
that means it has an audio error.
Dec 31, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony kp-46wt520
There are 762 parts available for this model. If you have the specific part number, they will likely have it. If you need help you can call them.
http://www.partstore.com/Model/Sony/Sony/KP46WT520.aspx
Dec 30, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-46WT520
Replace Diode 6301 and D6116,6117
Nov 21, 2008 | Sony KP-46WT520 46" Rear Projection...
What does it mean?
give me day or 2 i will resolve your problema
Nov 01, 2007 | Sony KP-46WT520 46" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
