Question about HP Compaq Evo n610c Notebook
Evo N610c Laptop. I get an attempt to start and an immediate shutdown every
3 to 4 seconds. I successfully replaced the hard drive and all worked well
until I started to troubleshoot a battert issue. The HP web site indicated I needed to update my BIOS, which I did. After completing the download, my laptop went for a restart and shutdown 3 to 5 seconds later. Now All I
get is a constant attempt to start and then shutdown. No image on the screen and no keyboard stroke is effective. HELP !!!!!!
Thanks
    Sergeant:
    Champion:
  • 334 Answers
Can u get in bios remve all power then plug back in not off battery use direct plug defult new bios f1 f2 f11 ect
Posted on Oct 07, 2008
I want to upgrade the RAM to 1 gig in my evo 600c what memory should I get that will work? Ive put in a new 50gig hard drive but its really slow
Evo n610c Laptop
Maximun Memory 1024MB Non ECC
Unbuffered CL=2.5. DDR333
2.5V.
DDR PC2700
Number of Slots:
Slot 1 Slot 2
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot
I have the same laptop
Nov 02, 2010 | Compaq Evo N610C Notebook
I have evo n610c laptop but when ever i turn on the laptop itgives a messege that non disk system or disk error with some sort of noice coming from hard drive
This error message could be caused by the laptop not detecting the hard drive.
Check the BIOS to see if it detects the hard disk
If not the hard disk may be faulty or needs reseating. If the hard disk is faulty it needs to be replaced and Windows installed on the new hard disk.
A virus program may have infected the computer and removed or changed some system files - in this case Windows needs to be repaired OR Windows re-installed - this is the best option.
Aug 15, 2010 | Compaq Evo N610C Notebook
Problem loading os on compaq evo n610c
Make sure you start by deleting the old partition, and formatting C:. If it still locks up after that, then your hard drive is bad.
Nov 21, 2009 | Compaq Evo N610C Notebook
I have an Evo laptop and the hadr drive died. HDD2181. Can you use an external drive without the internal drive? Or where would be the best place to get a harddrive?
You are able to use an external hard drive as your main drive but you will need to boot it at startup. If you need more help then just ask
Thanks
Cbz123
Nov 20, 2009 | Compaq Evo N610C Notebook
I can;t boot my laptop compaq Evo N610c from cd-rom drive
Disable the SATA option in BIOS settings then it automaticaly takes the CD ROM
Mar 04, 2009 | Compaq Evo N610C Notebook
Evo N610c wont boot up
hi!
9/10 it can be hard drive failure it means replacing the hard drive:)
regards craig
Feb 15, 2009 | HP Compaq Evo n610c Notebook
SHUTTING DOWN
Whining usually comes from the hard drive and indicates that it's beginning to fail. Locate the hard drive in your machine, hit the power button, then listen to see if the sound is coming from the hard drive area, if so, then the hard drive is beginning to fail. As far as it failing, it may go the next time you turn it on or it my last for months, hard drives a funny that way.
Jul 07, 2008 | Compaq Evo N610C Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Compaq computer shutdown
This can be due to several reasons
1)The charger is dead-> Try a different charger
2)The dc powerjack on the laptop is burnt(you have to take it part and check it...
3)Last but not least it could be a battery problem..you have to get a new battery..
Mar 26, 2008 | Compaq Evo N610C Notebook
Compaq EVO N610c
Hey there i might be young im 14 years old but i have the same laptop (Compaq N610c) and i had the same problem i found out that if you take the ram out and rub the small golden plates with a rubber then place it back (the ram is found next to the mouse pad) i then powered the laptop up without the hard drive i then took the battery several times and powered up it then started working again within 5 mins of taking the battery in and then taking it out again it then starting to power up with the screen showing the logo at the begining after it had shown the logo i turned it off then inserted the hard drive back into the laptop and powered up it worked and is still working now Hope This Helps :D My Email Adress Is znet-productions@hotmail.co.uk
if you have anymore problems.
Sep 11, 2007 | HP Compaq Evo n610c Notebook
HP Compaq Evo n610c Notebook Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
