Question about Whirlpool Dryers
Whirlpool dryer short? Help Me Please!
Electrical cord connection touched back panel of dryer as I was pulling dryer out to clean. Connection sparked and now the dryer will not start. Would this most likely have shorted out the motor or just the switch and how can I tell? I can replace either of them myself, but need to know how to proceed. This is in a rental and I do not want to spend to have a repair professional come out.
Can anybody please advise. Thanks.
626-797-1721 or gsmla@msn.com Geoff
  • 943 Answers
Hi thanks for the question. when you shorted that wire, it probably blew a fuse in the fuse box. check there first.
Posted on Oct 07, 2008
Our dryer wont start and the outlet doesnt give us power. The circuit breaker works until we plug the dryer in. Please help
most likely the heating element is shorting out or a wire is touching metal in the dryer or you have a problem with the house electrical,unplug it,pull it out and remove the vent line and the back panel,first check the connections where the cord connects to the dryer and make sure that's ok.if that looks fine go to the heating element connections down on the bottom right hand side,pull off the wires going to the element,check the element with a meter or make sure the wires aren't touching anything and plug it back in,if the fuse doesn't pop change out the heater,if it does pop again call an electrician to check the house circuit or and go through the dryer to see if any of the wires are shorting out,
Sep 22, 2011 | Whirlpool LER4634J Electric Dryer
I have a whirlpool inglis dryer that is about 5 years older and I have a 3 prong electrical cord, in the back of the dry were the electrical cable connects into the dryer (There is 3 connection locations)...
Hi johnebrenner...
Most likely cause of the wire being burned is a loose and arching connection.
I would recommend that you replace your existing cord and wire with new ones and make sure to tighten your connections very tight, but do not strip the screws by over tighting..
Please take time to rate me
Aug 23, 2011 | Whirlpool Inglis IP8200 Dryer
My Whirlpool Duet dryer has a strong. "Burnt"
Hi
The burnt smell usually comes when the motor is going bad, as the unit works I won't recommend you to use it for a long time and get the motor checked-replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My tumble dryer keeps throwing the trip switch I have cleaned all the vents and there are no blockages with fluff anywhere, can you help please
turn off breakers, unplug dryer and inspect the cord end for signs of burning, also open up the dryer plug on the wall and look inside it for loose or burnt connections, you could also have a faulty control thermostat ,shorted heating element or a bad 30 amp breaker in the power panel. Hope this helps Tim
Oct 24, 2010 | Whirlpool GEW9250 Electric Dryer
Basic whirlpool electric dryer
Remove power source and then remove top panel to expose timer and check for burned or arced wires. Check also your power cord at the connection.
Jul 05, 2009 | Whirlpool LER4634J Electric Dryer
I have a havy duty dryer Hotpoint and 1 of the 2 fuses is melting. The fuse are getting hot when the dryer is working. Need help Yvon. Tanks
You have a poor electrical connection, causing the fuse to heat up. Check to make sure electrical connections are all tight, especially the wires in your fuse disconnect box. Most fused disconnect boxes have a hex screw behind the fuse that the back of the fuse touches. Make sure that is tight also. The poor connection could be in other areas also, such as the receptacle the dryer cord plugs into or the connections of the dryer cord to the dryer.
Oct 21, 2008 | Dryers
Whirlpool Dryer has fried wire
this is quite a common thing to happen and is caused usually by the connection coming a bit loose causing a high resistant joint.
carefully clean up the joint and remake the connection
Sep 01, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer problem
ck vent system to outside also ck the vent hose behind dryer to be sure it is not being mashed flat when pushed back..while you have it out ck to see if cord connection screws are tight loose screws can cause cord to overheat and melt insulation causing short..if breaker trips immediately suspect dryer if runs for a time before kicking suspect weak breaker
Aug 09, 2008 | Whirlpool WED5100SQ Front-Load Electric...
Replaced timer however time does not count down and dryer won't heat up
one thing to check it the voltage coming into the unit make sure you have 220-230 volts at the plug if so you want to open the back little panel where the cord goes in and check your terminal block and cord connection PLEASE unplug b4 you open the panel A dryer will still tmble but wont heat or advance if that leg(110volts) is not there and the other one is
Jan 20, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
71 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
