Question about Kenmore 744-08BH Mechanical Sewing Machine
The top thread
I have not used a sewing machine in 20 years and I forgot the pattern for the top spool. Seems like it made a v pattern and then down through the needle. Can someone remind me?
Thanks,
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Oct 08, 2008
Brother750e in-no is dowloaded photo transferred to stitches using foil thread or embroydery thread , top thread keeps breaking, I've changed the needle don't know what else to try . Please help
Metallic thread is often easier to break when sewing. Make sure the thread is not brittle and old; It may also require "Metallic Embroidery" needles that have a slightly larger needle groove and eye spaces. Also, make sure your thread does not have additional tension on it when being fed from a vertical spool. allow the thread to flow horizontally off of the thread spool into the machine.Or place the spool bottom down on the table next to the machine and let the machine pull it up and over through the machine which needs to be very properly threaded.
Cheers,
Embroidery Services
San Diego, CA
Jul 09, 2016 | Brother Sewing Machines
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Top thread janome tension
it's possible that the spring got damaged & it needs to be check at a sewing machine shop
Mar 19, 2012 | Janome Sewing Machines
My LS2125i will sew a straight stitch but when I turn it to a zigzag stitch it takes a couple of stitches, then all of a sudden the top thread on the spool holder goes... whirl and winds the thread around...
sounds like your thread is getting caught in the thread spool's thread keeper notch. Make sure you use the spool holder disk with the closest size to the spool of thread to help prevent that. This is pretty common with old fashioned spools like coats and clark spools.
My brother suggests that i make sure the spool unwinds in a certain direction. You might check your manual to be certain the thread is unwinding the correct way.
Good luck.
Dec 18, 2010 | Brother LS-2125 Mechanical Sewing Machine
New Home sewing maching, using Gutermann thread to sew faced, turned "windows" (square)....PROBLEM: the machine checks, the thread pulls, seriously nests on the underside and I notice that the thread...
1.put new spool of thread on
2.watch the thread on the take up lever,make sure it doesn't come off
3.check the tension disk for loose threads, if there are threads pull out
4.check needle for being bent or blunt --if so replace
Jul 29, 2010 | New Home HF-1012 Mechanical Sewing Machine
I have a Simplicity Embrodery Machine, and the needle keeps breaking. I have checked the bobbin, changed the bobbin, changed the thread, changed the pattern. It sews for about 5 seconds and then breaks.
It could be the thread is hanging up and breaking the needle.
Check the thread spool for nicks - turn the spool so the thread is feeding from the bottom of the spool.
Watch the thread as the machine stitches, if the thread is pooling at the base of the spool, use a thread net on the spool.
Open the needle plate and remove the bobbin and bobbin case - clean out any lint or thread snips that may have accumulated there - do this often to help the machine work as it should.
Feb 19, 2010 | Simplicity Sewing Machines
HUSKY DELUXE SEWING MACHINE
Your local Husky dealer or via their head office in your country ought to be helpful unless they are out of print.........if so, ......Try sewusa.com or sew4less.com
Jun 01, 2008 | Sewing Machines
Need manual for 11301 barbie sewing machine
Anyone who needs a Manual for this Barbie machine I have it in pdf.
Someone tell me if they want it posted.
thanks,
Bonnie
May 03, 2008 | Barbie 11301 Mechanical Sewing Machine
How do I thread it
Follow the thread from the spool through the first thread guide at #1 straight down to #2 and up to #3 (make sure that the thread is through the take-up lever (silver hook) at #3 from three you will bring the thread straight down to the thread guide that is to the left of the needle. Thread the needle from front to back.
Mar 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore 744-08BH Mechanical Sewing Machine Logo
66 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
