Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
RX680 Printer Error
My brand new RX680 when turned on keeps asking for ink cartridges to be installed (Even though they are already installed) after a few seconds the carruiage starts initializing but only moves about a quarter inch. Followed by paper attempting to load. Then the printer screen displays
"A printer error has occured. Turn off printer and turn it on again. Please see your documentation"
Truning it off just repeats the process.
Any ideas as to what's going on and how to fix it?
Pete
  • freestyle104 Jan 11, 2009
    Re:cmullen-1
    thank you so much for posting that you just saved me from going through a mess with the guy i just bought this printer from on ebay this fixed it thnx again :)
  • Anonymous Jan 19, 2009
    Same problem, I changed the black cartridge and it keeps saying the ink cartridges cannot be recognized and I should make sure they are properly initialized.
Was given printer when someone got new and had same issue, dell replaced and let them keep the old printer. after a hour or looking for a solution on forums i started going over the printer. there is a small panel on the rear opposite side as power cord. I removed the panel to find some connections and a ribbon that was not completely in place. after securing the ribbon in place printer worked fine.
Posted on Dec 04, 2008
  • 34 Answers
Try turning it off and taking out the ink cartridges and putting them back in. If that doesn't work it could be defective. If it's new then it should be under warranty.
Posted on Oct 07, 2008
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
I have installed 2 new inks and still get a message asking me -- install new ink cartridges to continue .. I purchased these new inks 2 hours ago.
Install the cartridge by following the steps given in this link.
If the problem persists you will need to reset the printer.
Follow these steps to reset the printer:-
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message continues, go to the next step.
Also, Don't forget to remove nozzle protective tape from the cartridge using the pink pull-tab.
Do not touch the copper contacts or the ink nozzles
Good Luck and have a nice day.
Jun 09, 2010 | HP Photosmart D7460 Printer
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Cant scan to computer
Unfortunately many of the All-In-One devices are like this. If the Cartridges are installed but empty the system is reading that fault code as the Cartridges not being installed. Even though you are not using the ink the printer is most likely doing a light head cleaning when it cycles. Replace teh cartridges and it should clear up.
Aug 27, 2009 | Canon PIXMA MP470 All-in-One Printer
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
Changed ink cartridges - error still says I need to change them
Call Epson tech support and then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Canon Pixma IP600D - error code 6502
What is the brand name and model of your printer? Make sure that your ink cartridges are precisely the correct cartridges for the brand and model that you are using. From what I have experienced ... if you try to use a used ink cartridge you will recieve an error.
Please refer to the following link http://www.coldreset.com/modules.php?name=News&file=article&sid=60
Terry
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
My cannon pixma mp800 does not recognize the cyan ink cartridge, which is brand new.
I had same problem with yellow ink cartridge. After going thru other suggestions I found on different forums that didn't work (turning printer off and on, cleaning contacts with alcohol, taking out and putting cartridge back in several times) I finally called Canon as my printer was still under 1yr warranty, and they sent me a brand new cartridge free of charge and it works great now (even though my cartridge that was giving error mssg was almost brand new too). I think they have a lot of lemon cartridges out there.
May 09, 2008 | Office Equipment & Supplies
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
614 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
