Question about E-Machines eMachines Desktop PC
No video on monitor, My T3256 just beeps every few seconds. HELP
My subject line tells it all. The only thing the monitor does when powered up is say analog, then, digital. Re plugged in all cords, doesn't do anything different.
Thanks, Greg
  • 158 Answers
If u r pc giving 3 times beep then check u r memory(RAM) or change u r memory, or may be there was a problem in motherboard also check that
rate m
Posted on Oct 07, 2008
    Genius:
  • 1,124 Answers
Check the back of your computer, may be your monitor is connected to the wrong video port. Sometimes the computer have 2 video connections, one is built-in on the motherboard and the other one is a external video card inserted on the slot of the motherboard. Check both.
If you still don't have video check your video card. Put another monitor and see what happen.
T3256 beeps once every ten seconds
Hi
Try giving it sometime time for the transition and then reboot the system.
Check the RAM for possible damages on the contacts.
Hope it helps.Thanks!
Feb 18, 2012 | E-Machines Computers & Internet
HP Pavilion a1230n had bad power supply I changed it out for a better one of the same make and model. Now when it turns on I can hear the hard drive spinning and the fans running but it beeps every few...
If the beeping is coming from the power supply, that typically means that you are pulling too much wattage. I would recommend trying a higher wattage power supply. The video card is one of the lowest things on the computer's list of things to keep running at all costs, because even if your video card flickers off, you won't lose data. Before getting another new power supply though, I would ensure that your video cables are properly plugged into your video card and your monitor. To be sure that they are snug simply screw them in so that they don't wiggle at all when you pull on them.
Jun 10, 2011 | HP Pavilion a1230n (EG134AA) PC Desktop
Machine will not boot-up.....beeps 3-3-1.....please shed some light on the subject
do you know the make and version of your BIOS?
  • 1 long and 1 short beep = bad motherboard
  • 1 short and nothing else happens= disk drive/video related problem.
  • 1 long and to short beeps = bad video card
  • 1 continuous beep or non-stop short beeps= bad power supply
  • 3 short beeps = bad memory
if you can tell what you are trying to do i may be able to help further.
Oct 08, 2010 | IBM ThinkPad A21m 2628 Notebook
When i turn on computer screen is blank and the hard drive light is a solid amber for a minute then nothing....bad video card? Does same on two different monitors.
Video is on-board the motherboard on this model BUT you can buy (or borrow) a video card pretty cheap. When the computer starts up, do you hear any 'beeps', etc.? Might be something other than the video card...
Nov 21, 2009 | E-Machines T3256 PC Desktop
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
Monitor Shows pixelated colors then flashes no input and turnsoff
If it is a desktop, try another monitor and see if you're gonna get the same problem. If its a laptop, connect an external monitor to it. If the other monitor shows the same thing, it means to say that there's just something wrong with your video card. If that's the case, you might as well uninstall and reinstall the video driver. If in the other case, the other monitor's fine then definitely its your monitor. if there's a reset button or a factory reset button available on your monitor then reset it. If the same thing happens, get it replaced.
May 06, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
ECS 865PE long beeps monitor does not come on
u said the AGP video card doesn't seem to be getting power, right? May be your PSU is quite lower than your computer requires to run perfectly. Pls try to change the PSU and see if the problem gets solved....
Mar 08, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
Well the fact that your computer beeped tells me that there was a fault in either the motherboard or the video card. I would first replace the video card.
Dec 17, 2008 | Dell Dimension 9200 PC Desktop
Viewsonic VG 900 displays briefly, then goes blank
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
bammbammfran
Oct 11, 2008 | ViewSonic VG900b (Black) (10 Pack) Monitor
E-Machines eMachines Desktop PC Logo
89 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
