Frigidaire (ATF6000ES) Front Load. My machene motor is working properly but profeller is no swing forth and back
  • 29 Answers
I don't really understand this but you may need a new belt if the motor turns but the inner drum doesn't.
Posted on Oct 13, 2008
ATF6000ES frigidaire will not spin all the time only sometimes
Mine would only spin on the fast final cycle. Wouldn't spin during any of the agitate cycles. I replaced the motor, the speed controller and the main control unit. Nothing fixed the problem. Btw, the door lock worked properly. Had to replace the washer. Sorry, I know this doesn't help.
May 28, 2014 | Frigidaire ATF6000ES Front Load Washer
During the wash cycle, an error HE appears, and the wash cycle stops. the clothes are soaked with water
Hi areej, this is AP! Thank you for your post.
I understand you are experiencing an HE indicator during the wash cycle on your Frigidaire front load washer. I would recommend contacting a local technician as this appears to be a problem within the motor speed control board. However, I would recommend a local authorized technician to come out and properly diagnose and repair your front load washer. I hope this information helps.
Mar 05, 2014 | Frigidaire ATF6000ES Front Load Washer
I need a manual for the Frigidaire FAFS4272LW Front Loading Steam Washer
Hello Ann Todd - I located the manual on the Frigidaire website. Here is the manufacturer link and according to your model it seems like the direction of the door swing cannot be change. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 16, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer is flashing E90
Hello davis_04 - Error Code E90 typically means that you have the unit may possibly be experiencing an issue with the lock motor assembly, have a faulty motor door latch, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order for the wall oven to properly be repair.
Nov 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Drum is loose moving back & forth, water leaks & water do not drain from drum
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigdairr Frigidaire GSTF1670AS0 will not agatate or spin the motor trys to turn but cant> is the motor the likley problem?
it could be the problem but the first thing i would look at is the drain pump and check for anything that may be obstructing it from turning this will cause the washer not to run properly
Feb 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Installed a new timer in my frigidaire model#fwt449gfs1 now it will not enter final spin
check the motor controller for proper operation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Frigidaire ATF6000ES Front Load Washer
How do I put the belt on a frigidaire front loader washer
take the back of ,,might be 15 phillips head screws..around back,,than put belt on motor pully..and than on tub pully hold with one hand and turn,,either way..onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi there, ive got an frigidaire washer atf6000es frnt load
yea board or latch)latch usually shows fault. the board is located left rear of unit, first ck for loose wire connection leading to it.
Oct 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
