Question about Brother MFC-5840CN All-In-One InkJet Printer
Mfc-5460cn print unable 34trobleshooting and routine maintenance says unable to print. there was no paper jam abd it says to referto the users guide for troubleshooting. What can i do?
  • Anonymous Oct 16, 2008
    the printe say unable to print see troubleshooting and maintenance chapter in user' guide
  • levine244 Dec 18, 2008
    The printer pulled 3 sheets of soft card stock. I get a print unable 5A message, and a reference to the troubleshooting and routine maintenance. I cannot find the original guide. What do I do now?
Now the printer bar is all black lines neatly lined up and I can't even shut it off!!!!!!!!!!!!!!!!!!!!!
Posted on Oct 13, 2008
Says unable to print 4f, see troubleshooting and routine maintenance. please help.
This is a print head failure of some type. Turn off the printer, disconnect the power cord and lift up the scanner unit. Check for any paper or foreign object. See if you can slide the printhead and check under it. If the printhead will not move easily, do not force it. If the printhead is all the way to the right, you will not be able to move it. Use a flashlight to check for any foreign objects or paper scraps soaked with ink. Remove any foreign stuff that you find.
Sep 15, 2010 | Brother MFC-5460CN All-In-One InkJet...
MFC-240 I had a paper jam the other day and I
May be you should have the printer checked by a qualified technician.
I guess that when you aunt removed the paper, she did it by applying excessive force causing damage to the printer mechanic.
Mar 15, 2010 | Brother Multi-Function Center MFC-240C...
I have a MFC-5460CN and it is flashing across the screen "print unable 30 see troubleshooting and routine maintenance chapter in user guide" and we do not have a user guide
The 30 error says the carriage is not moving freely. Look on the extreme right and left with a light and see if there's a paper wad on either side. If you had a paper jam you could have pulled the encoder strip out of the sensor slot on the carriage and may need a shop to repair, but check for paper first.
Feb 01, 2010 | Brother MFC-5460CN All-In-One InkJet...
Had a paper jam, took the paper out, now it will not let me print It Says ''unable to print, see troubleshooting and routine maintenance chapter in users guide. I don't have the guide. Can you tell me what...
its possible your encoder strip came off of the printhead assembly.
you will need to check by taking off the scanner assembly, then the upper cover.
look at the encoder strip and see if its in the groove of the printhead.
May 07, 2009 | Brother MFC-3240C All-In-One InkJet...
TROUBLE SHOOTING
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
Print unable 30 & print unable 50
I had the same problem. I got a sledge hammer and hit it till there was nothing left. Then I bought a new printer. Takes the frustration out of the fix
Jan 26, 2009 | Brother MFC-5460CN All-In-One InkJet...
Unable to Print
plz try by reinstalling the printer
Nov 27, 2008 | Brother MFC-620CN multifunction Color...
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
