Question about Frigidaire ATF6000ES Front Load Washer
Atf 6000 front loader not spinning or draining
My washer is a little over two years old and we've never had a problem. I did one load today, and then during the second...it started to make funny noices when spinning.
The load just ended in error, still with water in the basin. I tried to run a spin only load, but nothing. The washer just hums.
Does anyone know what the problem could be? Motor or drain pump maybe?
Thanks, in advance.
  • 943 Answers
HI .you probably have a no drain problem. remove bottom panel. the pump is on the right. put drain hose on the floor, in a bucket, drain water out. check the pump. remove the hoses to the pump. clean out. thanks the appliance doc please rate my answer.
Posted on Oct 07, 2008
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
170 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
