Question about Lexmark Office Equipment & Supplies
Lexmark t522 fuser error 922, and i replaced with a new one same errot.
  • 300 Answers
SOURCE: I have a Lexmark X422 It
This means Fuser failed to reach
standby temperature.
The only answer is to replace the fuser, part number 56P0648 110 VOLTS, 56P0671 220 VOLTS.
Please advise if you require instructions
Posted on Aug 04, 2008
  • 3 Answers
SOURCE: Lexmark T642 Laser Printer error message922 02
Service fuser error requires a maintenance kit, this is approx $1000 + installed, if this is new, I would be taking it back because it shouldnt have this error. You possibly might be able tto fix it by replacing the fan in the back but thats only worked for me in approx 1 out of every 10 times.
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: I am getting a 922 fuser error on a Lexmark laser printer.
Hello. My dad had the same problem with his lexmark printer and he took it to a repair place where he was informed it is a problem with some part of the mother board causing the info from the computer to not be read by the printer. Long story short... is cheaper to buy a new printer than to fix the problem. He was also told this problem occurs in many lexmark models. Hope this helps you.
Posted on Mar 24, 2009
  • 26 Answers
SOURCE: 922 Server Fuser Error
922 fuser errors is a bad fuser - you might try turning off printer - holding the select and return button down at the same time - turn on printer - HOLD buttons until it starts inting (about 15 sec) and the arrow over to print test pages - if the error doesn't return - repeat a few times.... this may by pass the error.. then power off - ON and see if problem is gone. replace fuser if not
Posted on Apr 16, 2009
  • 320 Answers
SOURCE: 922 service fuser error
a 922 error is created by an open ac circuit(lamp circuit) on the fuser. the t520 t 522's have lamp holder problems that allow arching from the ill fitting metal contact to the end of the heating bulb. it is not uncommon for the end of this contact to be cut completely in half by the arching causing the 922 error. there are 4 components making up this circuit #2 lamp holders a thermal fuse and the bulb it self. percentage wise for this arching causing this failure is really close to 99.5% of the time. this damage is clearly visable if you remove one of the lamp holders and look at the contact
Posted on Jul 08, 2010
922 SERVICE FUSER ERROR
922 means the fuser did not reach operating tempture. most likely the bulb in the fuser has gone out. Depending on how old your printer is, the fuser could need either rebuilt or replaced.
Feb 23, 2012 | Lexmark T630 Laser Printer
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
    • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    922 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine. A replacement might be needed for LVPS, the fuser or worse the system board.
    Jun 28, 2010 | Lexmark T522 Laser Printer
    E 352dn Mono Laser Printer: error 922 service fuser error...
    Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
    If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
    May 18, 2010 | Lexmark E 352dn Mono Laser Printer
    I am getting a 922 Service Fuser Error what does that mean?
    a 922 error means that the ac circuit is open. this is the heat lamp circuit. a burned out bulb, blown thermal fuse, or pitted contacts will be the cause. replace the fuser and your back up and running
    Oct 06, 2009 | Lexmark Optra T610 Laser Printer
    Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
    Error 922
    I'm assuming the printer is saying 922 fuser error. If so it won't print at all until you replace the fusing unit. Its fairly simple to do. I'm new to answering on this site and wish I could give you my email so I could get you the fuser and tell you how to do it, but I'm not sure thats allowed as I'm in the printer repair business and I don't think they want you soliciting business on here. You may have a local repair place in your area.
    Mar 18, 2009 | Lexmark Optra T614 Laser Printer
    Jan 13, 2009 | Lexmark T642 Laser Printer
    I have a Lexmark X422 It has a error message when I try to print anything. It says 922 service fuser error
    Aug 04, 2008 | Lexmark Office Equipment & Supplies
    I am getting error 200 on a t522. This is being used as a repacement for another t522 which is displaying 'Std Bin Full' message after inreplacing fuser Thanks Michael Cotter
    where the paper spits out , there is a little arm that is stuck in the up position. maybe the spring came off. You will have to take the top cover off to see this.
    May 28, 2008 | Lexmark Office Equipment & Supplies
    395 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
