Question about Level 9 Sound Designs Monsoon Planar Media 9 Speaker
Monsoon power cord needed on old computer speakers
Hi, I just got some used OLDER computer speakers but the DC 15v cord is gone.
It says DC 15v 2A on the back.
Also:
SPARES P/N 160154-001
S/N 50008014
Any ideas or Help you can give me to get these up and running?
Where can I buy a cord that will work?
Thanks,
Leela
    Problem Solver:
  • 6 Answers
Leejean
the very best way to solve your problem, go to the electronic store and ask a dc power supply adapter 15volt 2A,vice versa polarity. with universal connector for it sure you can select the right type connector do you have for it fit to the back socket of your unit. before you connect read the correct polarity of your device you see label at back (+, -). and set the polarity output of the adapter correspond to your unit,,,
johnfil,,,,
Posted on Oct 08, 2008
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
Hello\r\nI have a kc-2a camera and would like to know what the pinout is? hope you can help thank you K.V
Its RJ11E. If your system doesn't support RJ11E, you can find a adapter at B&H (that's where I got mien) to connect to a BNC DVR. Make sure the camera has the right Power supply. KC-2A use 15V dc... most camera's I have use 12V.
Aug 11, 2011 | Ultrak Kc552bcn Ccd Cctv Color Security...
The power supplies / ac adapters for my AW-871 speakers were both lost in a recent move. The speakers show input of 15v center + but no power spec. Do you have a suggestion for replacements? Thanks for...
Higher voltage then required is not so recommended, internal circuit may over voltage driven. some power amp max limit may fall within 18V only. See this link If your speaker power less then 30w you can choose 15V 2A will do or else select higher spec.
Jul 23, 2011 | Acoustic Research 900MHz Wireless Stereo...
Need the AC 15V 1.1a power supply
Hi Tracy,
Wow, this was a hard one. I called both Harman Kardon and Dell, seems HK made the speakers for Dell, but neither company carries parts any more. I called Radio Shack thinking they would have a generic power supply, not even close. I looked at several places on the internet and had no luck.
I do have a little good news, I was able to find a few on Ebay, so if you don't mind buying used, you can get a power supply there. They even have a Buy Now offer so you would not have to bid on it. The power supplies are listed as 1100mA which is the same as 1.1A.
Also, if you get the it and the plug in is not the right size, take the speaker to Radio Shack and they will be able to sell you the correct plug, all you will have to do is splice in the new plug. With it having an AC output, you don't even have to worry about the wires being crossed as you would with DC. Hope this helps you.
Here are the links:
http://cgi.ebay.com/Harman-Kardon-A481511OT-15V-1100mA-Black-AC-Adapter_W0QQitemZ190450725250QQcategoryZ79846QQcmdZViewItem
http://compare.ebay.com/like/370463130288?ltyp=AllFixedPriceItemTypes&_dmd=Gallery&var=sbar&rvr_id=189044360544&crlp=1_263602_304692&UA=L*F%3F&GUID=0234523512d0a0b3f8f79f17ff3c9895&itemid=370463130288&ff4=263602_304692
http://cgi.ebay.com/Harman-Kardon-A481511OT-HK-01T-AC-Adapter-15V-1100mA_W0QQitemZ190450725272QQcategoryZ79846QQcmdZViewItem
Dec 23, 2010 | Harman Kardon HK19.5 Computer Speakers
I need a new power supply for Labtec LCS 1030 speakers and trying to obtain specs and power plug information. Anybody have the information available?
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
Feb 17, 2010 | Labtec LCS 1030 Computer Speakers
Need AC 15V 1.1A power cord for HK195 speakers
Hey, I was in the same situation. I tried a 9V DC (yes DC) converter I had and it works perfect. You can use a DC on a AC input - never the other way around. Due to insufficient power I get distortion at very high volumes... but I never play that high so I'm good..
Oct 07, 2009 | Harman Kardon HK206 Computer Speakers
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Jun 21, 2009 | Labtec LCS 3210 Computer Speakers
I have a Toshiba Satellite Laptop Model A15-S129 - The unit shut down and never would restart. I Checked the AC Adapter and it has no DC output voltage. I do have a 15VDC 2A Adapter connected to it now,...
hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try input..do not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
May 17, 2009 | Toshiba Satellite A135-S4467 Notebook
Don't remember how to use
I also have a Monsoon 320GB hard drive.  There is a power cord that attaches to the hard drive and the power source, make sure that the drive is turned off, plug the power cord in to the drive and the power source.  Mine came with two types of connectors to connect the hard drive to the computer.  Firewire to Firewire and a usb cord.  Use one of the cords to connect the hard drive to the computer.  Then turn your drive on.  If an icon doesn't show up on your desktop you can restart your computer, that usually works for me.  The drive functions just like your internal hard drive.  If you want to save files on the external drive just choose that option when saving a file.  Hope this helps.
Jul 30, 2008 | EZQuest Monsoon Hard Drive
Level 9 Sound Designs Monsoon Planar Media 9 Speaker Logo
688 people viewed this question
Top Level 9 Sound Designs Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Level 9 Sound Designs Audio Player and Recorder Expert? Answer questions, earn points and help others
