Question about Alpine CDA-9851 CD Player
IPOD hook up?
Were do i install my cable for the ipod?
    Sergeant:
  • 196 Answers
You need to purchase (if you do not have it already) the KCA-420i Alpine Interface Adapter for iPod (item # 500KCA420i). and connect it to the aux input socket
Posted on Oct 07, 2008
I need to down load iOS 4.3 on my ipod
Hi suetill56
Download and install the latest Itunes.
After you have Itunes installed on your computer and running, then hook your Ipod to the computer using the data cable.
The computer will recognize and update the ipod
Please take time to rate me
Bud
Oct 27, 2012 | Apple iPod 4th Generation MP3 Player
I must be hooking ipod up wrong dont know where
You should have a cable that goes from your ipod to a USB connection. Then you just plug the USB connection into your computer, then the other end into your IPOD
Aug 29, 2009 | Apple iPod nano
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
Ipod problems on my pioneer avh
To be working the ipod need to be hook up with the cable cd-1200 (not sold with the avh)and to be plug to the ipod plug on the back of the radio..if you plug the ipod on the usb it wont do..the cable is around 30 $ ..it is the good way to play your ipod ..but if you have a ipod touch 2 generation like i have it wont charge ..if you have any other ipod it will be charging when in use..
Mar 04, 2009 | Pioneer AVH-P4000DVD Monitor
How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Jan 04, 2009 | Bose Lifestyle V20 System - black Theater...
My Phase Linear UV8 and my Ipod
I wasn't able to find the manual for your Head unit. But, if you have jlink capability with your UV8 and you have an ipod jlink cable, you should just be able to plug the cable in. Then hook up your ipod and the head unit should recognize it when you try to select "ipod" for your source. I wish I could offer more info but like I said I wasn't able to see the manual and I am basing my answer off of what it takes for Kenwood headunits which use a similar "bus" type cable like your jlink. I hope I could help. Let me know if you need furthur assistance. I would happily help.
-Andrew Hawkins
Nov 24, 2008 | Phase Linear PCD120U CD Player
Make a ipod work on a panasonic cq-vd6505u
Ensure you have this cable (Panasonic Car Audio CA-DC300U iPod Connection Cable for Panasonic Car Stereos) or if you are wanting to put a Ipod with video you will need the CA-VDC300U. The cable plugs directly into the back of the radio or to the CYEM-100U expansion module. Once the cable is plugged in and the radio is installed (if you hooked the cable up to the back of the radio) turn your car on so the radio works, when the radio comes on hit your source button that allows you to switch between the DVD player and the radio. You should now see a button that shows your Ipod. This will allow you to control your Ipod through the radio and the cable will ensure you Ipod is always charged. This should work if you have the correct cable...I actually just hooked up my Ipod to the exact same radio today using the CA-VDC300U and the expansion module.
Oct 28, 2008 | Panasonic CQ-VD6503U Car DVD Player
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 17, 2008 | Apple iPod touch
Ipod hook up for VM9410
What i did is get the IPOD RCA cables and hook them up to the Auxilary femail RCA Cables attached behind the deck
Dec 30, 2007 | Jensen VM9410 Car DVD Player
Video Ipod audio but no video
the firmware is out and the ipod video works with 1.2.. i just tried it, was watching blow.
Dec 19, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Alpine CDA-9851 CD Player Logo
310 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
