Averatec Power Supply Issue
I just read your solution to a problem that I have been experiencing. I have contacted Averatec and they said that they could not fix the issue that I had to purchase a new power cord. Could you please direct me to the person that you spoke to that helped you fix your issue? I would really appreciate it.
    Genius:
  • 1,605 Answers
Don't know who you talk to.
but if you want, you can let me know what is your problem, the more information the better. I might able to help you.
Posted on Oct 15, 2008
  • 3 Answers
When my Averatec all in one needed a new power supply, the person at averatec tried to tell me it was the cord...
it wasn't the cord, so be careful not to just order one without trouble shooting first. They seem to have quite a large number of these units with faulty power supplies.
Posted on Dec 09, 2009
Error F68, beeping continuously
Hello Rasheda, this is Z. Thank you for your post!
If you are getting an error code F68 on your Electrolux oven, it typically means that your appliance may be experiencing an issue with the incoming line voltage. One of the best ways to determine if this is a false error code is to rest the power to your oven by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech since this is not a simple DIY job. He/she would need to determine whether the problem rests with the power supply voltage or EOC (Electronic Oven Control). I hope this helps explain the error code you are receiving.
Apr 10, 2014 | Electrolux Ovens
After completing a print project the power light went out and now it will not turn on. I cannot see where there might be a fuse to check. Do you have any suggestions? Thanks, Jim
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. 1) Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
2) Unplug the power cord from the electrical outlet, or the power strip or surge suppressor.
  1. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  2. Disconnect the power supply from the rear of the product.
  3. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  4. Reconnect the power module to the product.
  5. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  6. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on
  7. If the product turns on , the electrical outlet in the original room caused the issue.
  • If the product still does not turn on , continue with the next solution.
3) Disconnect the USB cable from the rear of the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. If the product turns on with the USB cable disconnected , replace the USB cable
  3. If the product still does not turn on , continue to the next solution.
4) If your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery
5) If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product
6) If you have completed all the preceding steps and are still experiencing a problem, service the product
Mar 26, 2011 | HP Deskjet 460 InkJet Printer
Bad power supply contact on the rightside of my Pavillion DV9000 dvd (GD545AV)
May i know what issue are you experiencing with your laptop? If it is a bad power supply then you need to have this one fixed by HP if computer is still under warranty.
Jul 09, 2010 | HP Pavilion dv9000z Notebook
Laptop cuts off after logging on, sometime it will only get to Windows XP screen. new battery installed and charged. Helllppppp!!!
If it is that the PC is totally POWERING OFF, then you have a power supply problem. You will need to have this replaced on the motherboard or replace the motherboard.
Mar 15, 2010 | Averatec 3150P Notebook
Hey, my dell all in one printer 810 will not power on at all. I have measured the traffo into the printer and it reads 30vDV so it has power but will not start
Hi
Disconnect the unit completely from the AC outlet for 5 or 10 minutes, then plug it back again.It will works.
Also I suspect it may be a loose power switch, or a problem with the power supply.
If it is a USB printer that derives power through the USB cable and not from a seperate power cable, then check the USB cable. That may be the source of the problem if the cable is bad.
Try the following solutions in the order presented to resolve the issue...
Solution one: Press and quickly release the Power button
Press and quickly release the Power button ( ) to start a Power On/Off cycle. Do not hold down the button .
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button ( ) again.
Solution two: Check the electrical connections and outlet
NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
Disconnect the power supply from the back of the product.
Press and quickly release the Power button ( ) to turn the product on.
If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button ( ) to turn on the product.
Solution three: Check the USB cable
Disconnect the USB cable from the back of the product.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01896072.gif( chek the figure)
Press the Power button ( ) to turn on the product.
If the product turns on with the USB cable disconnected , replace the USB cable.
Solution four: Check the battery
If the battery light is still red after recharge, replace the battery.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01468528.jpg( chek the figure)
1 - Slide the battery release slider in the direction of the arrow
2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site.
Solution five: Replace the power supply
If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product.
Solution six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks for contacting fixya.com
Oct 18, 2009 | Dell 810 All-In-One InkJet Printer
Power supply replacement?
try www.tigerdirect.com they carry tons of pc parts including power supplys i built my whole pc from their website and they have 24 7 live telephone support and if they aint got it they can get it im not trying to promote them but they aint never done me wrong
May 21, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Compu is averatec d1002uhce-1 2 month new .... i
sounds like either you have a disk in the cd drive and it won't boot because of it or you have some other device that it is looking to boot from instead of the hard drive.... if not, then you have a bad hard drive. I would first unplug all accessories and eject any discs... Next go into the bios (if your comfortable with it) and make sure the hard drive is in the boot priority... if nothing, then take the cover off and disconnect and reconnect your hard drive. If that doesn't work then you probably have a faulty drive.
Mar 23, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
