Question about Honeywell Programmable Thermostat Heater
Honeywell dial theromostat.
I hope you can help me.
I have a hard wired (no batteries), round type honeywell thermostat. Very basic type but only 4 years old. I have no a/c in the home, just forced air (gas) for heat.
The problem I have is the thermostat is not giving me any reading at all? Just a blank face (normally shows room temp). I have limited knowledge of working with furnaces but I did the following:
1) Reset the circuit breaker.
2) Pulled face off of thermostat and cleaned best I could.
3) Checked furnace for obvious signs of loose wires, dirty fan, clean filter,etc.
Nothing worked?
Its getting cold in here and I need heat, please let me know what else I can try before calling in a service tech.
Thank you.
  • enloe Nov 01, 2008
    I have the same problem. It just happened today. I don't know what else to do?
    Sergeant:
  • 359 Answers
You need to check the furnace itself for , locate the 24 volt ac transformer inside the unit and see if it is fused some are some not , check to see if you have 120 volt ac in from the source and 24 volt ac out , sounds to me as if you have lost the 24 volts ac which powers the thermostat as well as the furnace pay close attention as to how you remove the wires and make a diagram and you should be able to replace it yourself , once you get it uot goto a heating supply place in your area and let them match it up and this should be a fix ya
Posted on Dec 31, 2009
  • 308 Answers
I have seen this often with the digital round thermostats, for some reason they tend to just die, in my opinion prematurely. To ensure that this is the case, take the face off the thermostat, and check voltage between your two wires, you should have approx. 24 volts. If not, then it is a problem at the furnace, or in the wire. If you do have the 24 volts, replace your thermostat. Hope this helps
Posted on Jul 11, 2009
    Novelist:
  • 189 Answers
Since you say it has a blank face it must be a digital thermostat. if the power is on to the furnace and the furnace door is on (door switch) and still does not give you a reading. You probably have a bad stat. if you are handy.... unhook the wires in the thermostat. jump the red and white wires together. the furnace should turn on. if it does the thermostat is bad. if it does not turn on its not the thermostat its the furnace
Posted on Mar 28, 2009
  • Lou Barta Apr 11, 2009
    I assume that this is a digital thermostat. Disconnect the wires form the thermostat. Connect the Red wire and the white wire that are coming out of the wall together. This should turn on your heat. BUT keep in mind the furnace WILL NOT shut off untill you UNHOOK the wires. If this turns on your heat, replace the thermostat. I recommend that you do not replace it with the same style. ( that perticular style is not very dependable).
    Good luck.....
2 Suggested Answers
  • 70 Answers
SOURCE: Furnace kicks on every 15 mins
fuanace may be oversized and is short cycling it heats up house to fast it is better when they run longer
Posted on Oct 04, 2009
Thermostat wiring
The thermostat contacts for heating are between R and W, if you have but two wires to deal with from the heater that is where they would connect. if the thermostat runs on batteries this should work however if it uses a 24V power source it is not compatible with a two wire system.
Oct 09, 2017 | Honeywell Heating & Cooling
I have a honeywell T87K round thermostat (2-wires R and W). I just purchased a honeywell WIF 7-day programmable thermostat RTH6580WF. How do I install the new thermostat? Is it even possible?
Programmable is in unit nothing to do wire fto urnace two wires cut furnace on and off you should have instructions to use two wires with your instructions
Aug 18, 2015 | Honeywell T87K1007 Mechanical Thermostat...
Honeywell com yourhome
Yes, it should work. Old thermo has 4 wires, follow instruction with new thermo.
Jul 22, 2014 | Honeywell Universal Digital...
There is five wires yellow, green, red, white, the problem that we a facing is to connect these wire into the honeywell theromostat RTH3100C1002-0916
yellow is the cool wire, green is the fan wire, white is the heat wire, red is the power wire. these stats should have a 1 letter icon ,r for red on stat y for yellow and so on ,make sure that Rc and RH are jumpered and install batteris if needed
Sep 29, 2009 | Honeywell Electronic Programmable...
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
Why can't i get my thermostat to work
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 22, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Furnace thermostat
Get to the wiring at the thermostat. Take a small jumber wire and jump from R to G on the thermostat. Hold it there a few minutes to see if the system starts heating. If it does, you have a bad thermostat. If not, you have other issues.
Jan 18, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
356 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
