Question about Sony KDF-55WE655 55" Rear Projection Television
NO PICTURE. Only getting a blue screen with black broken spaces. Due I need a new lamp replacement or is it something else please? Clueless D
  • 10,594 Answers
When tv shows dark picture or Lamp LED start flashing at front of tv then you need to replace Lamp.
Now let me know do you get blue screen on all video inputs or just on cable / antenna ?
It would be nice if can paste picture of tv showing problem to understand easily, like I'm pasting your tv picture as reference.
Thank you.
Posted on Oct 07, 2008
  • Shahid Electronics
    Shahid Electronics Oct 07, 2008
    This is Sony KDF-55WE655 / KDF-42WE655 model tv.
    Please confirm your tv model.
Black Screen
It sounds as if the lamp has failed possibly due to a failed cooling fan (the fan should be the first thing to come on). here are the links to the user manual if you need it; http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825.pdf and http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825_Part2.pdf It may be worth trying to uninstall and reinstall the lamp, but usually these fail internally rather than having bad connections etc. It is often obvious when the lamp has gone from a visual inspection. If the lamp has failed, when you replace it, make sure the fan comes on - if not then turn off instantly and investigate further. One other possibility before buying a new lamp, is that the lamp compartment cover may not be properly fitted. This will interrupt the power, so I am assuming there is a microswitch or similar that the cover or the screws that hold it should contact. Possibility is that the cover is badly fitted, or a small piece of the cover has broken, which would normally contact the switch, or the switch is faulty - if you can see the switch then a continuity meter will easily test the switch. Also check that the lamp unit securing screws are properly tightened, they also may stop the TV powering on. Please ask again if you need more help with this, if you are unsure then a photo of the inside of the lamp compartment and the lamp itself may help :)
Jun 26, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Black screen
It is likely that you now have power supply trouble.
May 26, 2013 | Philips Televison & Video
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
Blue screen is black and picture very dark
What did you have before you replaced the lamp?
Dec 07, 2012 | JVC HD-52G886 52" Rear Projection HDTV
What is wrong with my tlp s10 it gives the entire picture a blue tint the lamp has done 2700 do I need a new bulb
Check the Video cable that feeds the projector, could be a broken cable or a pin bent -worst case the connector on the projector has broken.
Try the VGA cable on your computer screen.
The lamp does not need replaceing, the lamp emmits white light only.
Aug 06, 2010 | Toshiba TLP-S10 Multimedia Projector
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Hitachi LCD rear projection TV has blue color in left corner
It is most likely the tube going out. Find some one to replace the tube if the TV is fairly new other wise it is going to be a trend. One tube now and another.. and so on. Ride it out as long as you can then go for an upgrade
Sep 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Samsung 50'' DLP PRblems
Okey dokey... you'll need to remove the back cover on this set and make an adjustment to a part called the "DMD board". The DMD board is a large, flat, vertically oriented board with a perforated thin steel cover over it.
Basically, there is a tiny tiny 'tv screen' on the front side of this board and by moving this board around you can 'fine tune' the picture position. All that is typically required is to loosen the screws around the perimiter of the board (JUST SLIGHTLY! You don't want the board to fall out of position!) and slide the board around, preferably with someone watching the screen, until the picture looks perfectly centered.
Something to keep in mind is that the TV will not operate with the back off due to their being a small switch with a blue lever on it whose purpose is to prevent the TV from powering with the lamp cover off. Just tape this switch up so your set will power and then you can rock and roll. Good luck!
May 18, 2009 | Samsung HL-T5087S Television
Sony WEGA 42" LCD TV
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with Sony and start complaining, then keep complaining until they agree to pay for it. Even if it is out of warranty.
You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Hope ya fix it!
Jan 07, 2008 | Televison & Video
Sony KDF-55WE655 55" Rear Projection Television Logo
99 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
