Can not burn double layer DVDs on eMachine T3958
It says it can burn 8,5GB double layer DVDs. It doesn't. It will burn single layer DVDs and CDs without a problem. I have tried Office Depot and Memorex double layer DVDs (8.5 GB). All fail.
The computer identifies the DVD Drive but when I put the DVD in the tray it converts to CD Drive. I can not send, paste or drop and drag. When I try Nero, it starts to transfer then aborts with an "illegal disk" error.
If I check properties, it is all blue (full) with 0 bytes used and left! I can not access a format I am at a loss...can you help?
What video format can it read?
According to the manual, under the Support/Manuals tab, the VM9216BT reads VCD, SVCD, XVid ,AVI, MPEG 1/2 formats. Commercial DVDs will work if you match the device Region with the discs region code. (All or Region 1 in the US). The DVDs should be DVD-5 (single-sided, single layer), DVD-9 (single-sided, double layer), DVD-10 (double-sided, single layer) or DVD-18 (double-sided, double layer). Note: video CDs and DVDs, like audio CDs, need to be finalized by the drive that burned them.
I hope this helps.
Sep 03, 2013 | Jensen VM9216BT
I have just bought a toshiba satellite c650d. Will it play DVD's. It is running on Windows 7 and has 4GB of ram
Toshiba Satellite C650D has a DVD Drive and it is capable of playing DVDs.Certainly, it will play DVD. It even supports High Defination (HD) video. So, ENJOY!
Hope it helps! Good Luck!
Don't forget to convey your feedback
Feb 03, 2011 | Computers & Internet
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
I cant burn cds dnt knw y?
do you have windows media to burn your cds?
Jul 18, 2009 | E-Machines emachines (emachinees) CD-ROM...
Can't get Blu-Ray DVDs to play through my Acer laptop to LCD TV
The specifications of this laptop states that it has a Dual layer DVD R/W drive. This drive can only play DVDs and CDs but not BluRay discs and it can burn single and dual layer DVDs and CDs.
Jun 20, 2009 | Acer Aspire 5610-4648 Notebook
Error burning to Dual Layer DVD
Do you have a dual layer burner, you need one to burn dual layer dvds that may be your problem hope it helps
Mar 25, 2009 | Global Marketing Partners Vhs To DVD 3.0...
Dvd troubleshoot
try to clean the lens using coton and water if not working change the lens.
Sep 16, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
Problems Burning DVD's
Ya didn't say what Operating System?... Ensure ya have all the correct "Settings" in the Burn software. Sometimes the actual type of DVD media can be an issue... some dvd's just don't "Like" some DVD's I have found... try the best brand ya can afford... if still no go.. try Alcohol 120% & CopyToDVD both use their "Own" "Drivers" and I have had great success.. where others have failed..
Aug 07, 2007 | Optorite DD1603 DVD±RW Dual Layer...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
