Question about Kicker 06ZX750.1 Car Audio Amplifier
Protection light won't stop blinking/ Subs don't work
Just installed this amp into my car. I know that nothing's blown because it has worked for a few minutes. But now everytime I turn my car on the protection light justs blinks and I get nothing out of my subs. Wiring is all good, everything is brand new. Any ideas would be helpful.
  • 1 more comment
  • kickazzgoali Oct 08, 2008
    Read through the troubleshooting guide, it may have something to do with the RCA's or Speaker wires. Tested this by taking out the rca's and speaker wire (sub amp powering 2 12's) when I turned my car to aux, instead of blinking the protection light was just on, no blinking. I then re-attached and they started blinking, took them off again with it on and it stayed blinking, weird. Also, put a voltmeter across the amp (power and ground) when the prot. light blinked off it showed 12~ volts, when the prot. light blinked back on (protection on) the voltage would drop anywhere between 1 and 3 volts, going as low as 9.5~ volts. Does this help? Is there more info that I could get that would be helpful?
  • gaspardc122 Oct 16, 2008
    my zx750.1 plays for 12 to 30 minutes and then the protection light blinks and cuts out my 10'' power acoustic sub off and on.I have checked all wirring and everything is wired right to the besy of my nowledge.I have tried my buddies speakers and had the same probblem.I have tried pulling wires one at a time and still got the same problem.The amp is remanufactured.Im thinking its the amp.Any comments REALLY appreciated.please email me at gaspardc122@aol.com Thaks verry much! ps.now my green ligt stays on and nothing comes out my woofer. please help.
  • Strick28 Jan 12, 2009
    Protection blinks in and out. I got the amp from a friend and it was used so thats prolly why he gave it to me. Fuses are good. What do I need to fix internally???
  • 631 Answers
The amp probably has shorted output transistors to eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Posted on Oct 07, 2008
Boss 5500 watt amp stays in protection mode
The amp is going into protection mode because one or more of the output transistors is fried inside. You want to check for resistance on all the outputs. I repair these everday. Either have it repaired or do it yourself. I buy broken amps and I also repair them. Let me know if you want to sell or repair or want instructions on how to repair it.
Jan 05, 2014 | Boss Car Audio & Video
I have 2 10" Sony Explod Subs and a 1000w amp. My fuze was blown but i bought a new fuze that was stronger. My system is still not working.
the amp has power, ground and emote turn on? is the amplifier lighting up? is it going into protection?check the wiring to the amp before you suspect a bad sub and amp
Nov 01, 2012 | Sony Car Audio & Video
The green light and protection light on my 1100d constantly blink and the interior lights in my car blink in sequence with the lights on the amp and I get no sound out of the amp and sub setup. What could...
Sounds like you have an issue with the amp, the install, or possible blown subs.. check, test and if all else fails get the amp serviced or get a new amp.
A good car audio shop can also help you check it over.
Feb 06, 2011 | Directed 1100d Car Audio Amplifier
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
Amp powers on, no sound from subs
the output is blown. It is in need of service.
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause.
Dec 28, 2008 | Alpine MRD-M1005 Car Audio Amplifier
My Jbl mono amp cuts out
It's likely that the amp has blown output transistors. To eliminate other possible problems, read through the following page:
Amp Going into Protection Mode
Sep 14, 2008 | JBL GTO75.4 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Kicker 06ZX750.1 Car Audio Amplifier Logo
385 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
