Question about Whirlpool Washing Machines
Machine is bouncing all over and i checked the load and its even than i took all the clothes out and its till doing it help, help
  • 247 Answers
You might try checking the damper struts - Inside the case you'll find that much of the machinery is suspended on springs. Alongside the springs, there's usually a couple of dampers (look a little bit like hydraulic rams or car shock absorbers).
Take these off (DON'T attempt to run the machine without them fitted). Slide them in and out. They should slide smoothly, but with significant resistance to rapid motion. If either doesn't feel right, replace it. They aren't usually outrageously expensive.
A.
Posted on Oct 07, 2008
Washing machine making banging noise intermittently during agitating
your loads are unbalanced during the time that it is making that noise, when it starts you may wish to make sure that the clothes are all evenly distributed in the drum so that all the weight isn't on one side. when the clothes all bunch up in one spot it throws the balance off of the drum just like a car tire that's lost a weight makes the wheel bounce, same principal
Dec 30, 2014 | Washing Machines
I have a maytag Neptune front load washer that bounces across the room
Good morning to you
Dancing washing machines are not the most elegant of dancers
There two things that you have tobear in mind.
1. that the machine stands on completely level and flat surface.
2. that the clothes load is evenly distributed inside.
hope this works for you
Kolbrun
Feb 26, 2012 | Maytag Washing Machines
The next wash, after a wash load using bleach, gets a few bleach spots. After washing a load using bleach, I've tried washing a load which would not matter if bleach contaminated it. Even the 2nd load,...
I would just put the bleach into the tub while it's filling and wait till it's about half full of water before adding the clothes.
It may help to pour the bleach into the dispenser then pour water in after it to rinse it out. Some washers say to do this in the manual.
Dec 07, 2010 | Washing Machines
Front load washer is bouncing around when spinning clothes. It's like it's unbalanced.
Adjust your washer's front legs and lock the nut, it has another nut to do this. After you have locked the legs, try to rock the washer with your hands, it should not rock. Another thing to check will be inside your washer, after taking the power off the wall socket. Check to see if some springs or the shocks (dampers) have come loose. This normally happens when the load is not even, that is when you have a big sheet in one part of the washer tub. Mix large & small clothes before you commence the wash.
To see if washer is firm: hold the front portion of the washer, the 2 corners and try to shake it, if it does not move, it is fine.
If helped pl give me a fine rating.
Jun 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Spin Cycle - washer starts bouncing around room even though level
There are about 6 pairs of springs to hold the bottom tube to the bottom chassis. If some of these came off from designed positions, the tube won't be in balance then the washer starts bouncing off. Make sure these pairs of springs in place then you have no problem.
Sep 15, 2009 | Washing Machines
Washer says "ob" and there aren't any clothes in the washer
some machines can be over loaded and under loaded u need to take the clothes out and run it with nothing in if it does it again with nothing in the sensors are faulty and u need an expert to check it for u
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Washing Machines Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
