Question about Philips Televison & Video
I have a philips 28pw6517/05 and it is started switching itself off and on. This happened for 1 day then it just or give sound.
What component controls the power switch for a Philips Flat Plasma TV, and can it be replaced?
Its main system control IC controls all functions of the TV. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Aug 01, 2015 | Philips Televison & Video
Asus U52F laptop -- 1 week old, a few days ago the internal wifi network adapter started randomly shutting itself off here and there throughout the days. Occasionally it switches itself right back on, but...
Sounds like a faulty wireless card or the card is installed with the wrong version driver.The wireless card itself sounds to be bad and needs replacing
Jan 10, 2011 | ASUS U52F-BBL9 Laptop
Tried to start the truck---nothing happened....the ignition key was turned on but nothing. 3 days ago, same thing happened I turned key and nothing. So what I did---turned key on till red light came...
sounds like a bad connection,it wont heat up the solenoid or the starter,check your hot and negative cables from battery to starter first could be the starter itself, ggod luck
Dec 20, 2010 | 1997 Chevrolet C/K 3500
Mitsubishi air con MSH18NV - blower goes off - LEDs remain on
Sounds as though you have a bad motor. Once the motor heats up the winding swell causing the motor to constrict itself. Once this happens a thermal overload switch kicks in shutting the motor down to prevent fire. Hope this helps you Philip. Good luck on your repairs
Sep 15, 2009 | Mitsubishi MSH09TW Air Conditioner
My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 15, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Volume keeps going down by itself. I'll use the remote to turn it back up and it goes back down to zero again.
It's rare but happens. Sometimes the volume button (or rather the plastic piece that activates the button when pressed) can get stuck. That or there has been a cleaning chemical leak down onto the button on the board itself and corroded it, causing a constant short.
As for the second Q, I feel that your TV may have received a shock through the audio line and the audio amplifier may have taken the hit. These problem can lead into multiple bad compontnts, such as a bad SMD IC on the bottom of the board.
Dec 26, 2007 | Philips Magnavox 27MS343S 27" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
