Im downloading songs on my cd , they work good when i play them on the computer,, but i want the songs for my car and my dvd in my car isnt taking it... what can i do ,,, change the format is what pple are saying??? can you help me on this issue
Thank u so much for ur in put , now could u walk me throu on the steps to convert them i am using i tunes and yes i did try to burn them wiith the mp3 files and it never worked , but i never tried what u suggust because i dont no how i should do it:( if u could walk me throu what u done wou;ld be greatly appreciated is itunes first of all a good program to use for the task......... be waiting for ur reply thank u so much
Posted on Oct 08, 2008
    Sergeant:
  • 196 Answers
Assuming your car dvd can first of all handle copied discs.. can it read mp3 files? (which is what you likely have the songs as) if the player can read copied discs but not mp3 files then you need to 'burn' the mp3's after converting them to wav files (must be at least 44.000 quality to be recognised as music tracks) the good news is most disc authoring programs will do this conversion for you IMPORTANT dont forget to finalize or 'close' the disc after recording it or it wont work
Posted on Oct 07, 2008
  • Jon Muncaster
    Jon Muncaster Oct 08, 2008
    If you have Windows Media Player it is quite simple to burn an audio CD Itunes I think not a good program for the task. in Media Player go to Library tab and select track(s) to burn to disc...(add your music to library if not already there by clicking the library tab and then 'add music to library' this is done automaticaly by Media Player normaly)
    When you have the track(s) selected click the Burn tab in Media Player and select Audio CD (should be selected by default) the tracks you chose will be converted to proper format and burned to CD
    Hope this helps
What do i need for a computer to start burning or to creat a cd/mp3/dvd .
First you need music to put on the CD. You can put your own music CD in the drive and run Windows Media Player and rip them to your hard drive (copies them). After you get all the songs you want onto your hard drive, you can make an audio CD if you ripped the songs as WAV files (this CD can be played in most CD players) or you can make an MP3 CD if you ripped the songs as mp3 files (this CD can only be played in CD players that support the MP3 standard). To make the audio CD or MP3 CD, just download the free program called BurnAware from the internet and run it. Insert a blank recordable CD in your computer, choose Audio CD or MP3 CD, then choose the songs you want and burn the CD. That's it.
Nov 13, 2013 | LaCie (LAC300920) DVD±RW Dual Layer...
CD drive is not working correctly
Hello try to download the manual from here:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
Please select your windows system.
Open the manual folder, and click on global for download.
You will need adobe reader, to read the content.
Check the bios settings for the audio, try to change the setting to
ac 97, instead of hd audio.
Try also to select the setting plug and play os. to yes.
Remember to save your work when leaving the bios.
Why are you useing both a cd and dvd drive ???
A dvd drive does also plays cd`s.
Are you useing sata or ide connection ??
If so the ide cable could be failing.
Update any drivers, if some missing.
Good luck
Jan 06, 2013 | ASUSTeK COMPUTER A8n-sli Deluxe Socket 939...
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Im trying to download music into my mp3 player the music I have in my computer is all store bought cd's during play back from the mp3 a few songs come up as format not supported,its confusing because same...
Hello Mr wesleyseeley
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Jun 04, 2010 | Philips GoGear HDD1830 MP3 Player
Songs I have downloaded to my sansa e250 mp3 player won't play
This is a simple formatting problem, To fix itSOLUTION 1:well there isnt really a way, other than instead of using windows media player directly, you can copy it out of the disc folder (in my computer) and into your my music folder and then import it from your my music folderSOLUTION 2:You can download itunes for free, upload discs to your itunes and then make a new disc (make sure it is in mp3 format<you will see what i mean>) and the rip the disc like you normally do Hope i helped If this doesnt work the email me at dirtyfairy@live.com.aucheers
Jun 12, 2009 | SanDisk Sansa e250 MP3 Player
Burnt songs and they wont play in my car???
im assuming you have a dvd player in your car as opposed to a regular cd player
you need to look in the manual of your car stereo and see what kind of discs it can read... there are dvd+r, dvd-r, dvd-wr, dvd-ram, dvd-r (dual layer), etc, etc....
make sure your using the correct format disc and also make sure when you burn the music that your burning them in a file format compatible with your stereo (wmv, mp3, etc) check the manual
Feb 07, 2009 | HP Pavilion dv6000z Notebook
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Sasung K3 Im using mix cd's
play on your computer in media player make a new playlist with all of your songs and then download as a complete playlist to your mp3
Dec 28, 2007 | Samsung YP-K3 MP3 Player
My ipod won't play songs I bought from itunes, and it won't let me download new ones.
Unfortunately, if you did not back up your music, the songs cannot be recovered. iTunes allows for one download of a song purchased.
Jun 07, 2007 | Apple iPod nano 2nd Generation MP3 Player
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
59 people viewed this question
 Grubhead
Grubhead
