Question about Nintendo DS Console
My Nintendo touch screen does not work.
It will not work with the stylus
  • Anonymous Feb 05, 2009
    helpppppppppppppppppppppp
    Scholar:
  • 50 Answers
Well, does the screen turn on and function correctly? If so, then you simply have the touch screen ribbon that is disconnected and if you open the DS you can correctly place the ribbon so the touch screen functions.
If you don't want to take the chance of screwing it up more, then simply sell it on eBay. You will get a good price if you describe the problem. Others who are experienced in this area will buy it, and that money could help you get a new one.
Posted on Oct 10, 2008
Screen touch
Refer to the trouble shooting at Nintendo. Your screen may not be working due to the game your playing if any. If that's not the case you may need to recalibrate your touch screen.
http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_screen.jsp#respond
Aug 15, 2013 | Nintendo Dsi Pink Console
My daughter has a DS Lite which works fine except the bottom left hand of the touch screen does not recognise the stylus - she has to touch the screen 3 or 4mm away from the actual point to make it work....
you could try to recalibrate the screen but unfortunatly sounds like you will have to replace the touch screen. its a very common problem.
http://www.nintendo.co.uk/NOE/en_GB/support/nintendo_ds_lite_159_154.html
Jan 05, 2010 | Nintendo DS Lite
Stylus
Its not the styles it the ds
May 22, 2009 | Nerf Stylus Twin Pack for Nintendo DS...
Screen does not react to the stylus when touching on found object
You could try calibrating the screen. To do this, you must go to the little DS in the center of the screen when you turn the DS on. Then touch the yellow square on the far right. It should give you instructions from that point on. Make sure that your stylus doesn't have a scratch on it! If it has a little nick down the middle, then your screen might not get a clear reading as to what you touched.
Hope it helps~
May 03, 2009 | Nintendo Mystery Case Files: MillionHeir...
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Nintendo DS Lite Touch Screen Fades
You're going to have to send it in for repair. It sounds like it's out of warranty, which is unfortunate.
Dec 05, 2007 | Nintendo DS Console
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
