Question about E-Machines eMachines Desktop PC
Emachine i a message that pops up and says low disk space on recovery (d ).i tried backing it up and even tried using my reboot disk that came with my pc but it says erroe on my disk. what to do?? sammie
  • Warren Held
    Warren Held May 11, 2010
    Did the reboot disk wipe all the programs off the computer? It sounds like you're out of space on your hard drive.
  • 158 Answers
U r d: drive is full delete some files and check it or backup u r files n e externel harddrive or pen drive from d drive
Rate m
Posted on Oct 07, 2008
RECEIVING MESSAGE THAT I HAVE
You need to uninstall programs, simple as that. The size of the files is to large to back up with your current programs and that is why you are receiving the message, your best bet is to try and get rid of things you don't use anymore. That or just move some of them over to a flashdrive/ portable storage.
Aug 17, 2012 | HP Computers & Internet
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
AM RECEIVING MESSAGE THAT MY
may be you are storing files and folder in your Recovery volume, It is not suggested to store things in your recovery volume.
Aug 14, 2012 | HP Computers & Internet
Was using system and then it just powered down. When started back up it stated that there was a system error and the options were to restart normally or to do a system recovery (recommended). Would only...
Hello.
From your description, sounds like a hard drive error: problem with recovery, hard drive message.
So, I'd recommend a replacement hard drive.
Hope this helps.
Oct 21, 2010 | Toshiba Portege M800 Notebook
Everytime i opened my computer a low disk space message appears. i"ve already tried cleaning up my disk drive but the message continues to pop up
> problem with Barcode Scanners
> low disk space
If your computer has a CD-writer or a DVD-writer, use it, and "burn" some disks containing your files (music?), and then delete the files from your disk-drive.
Then, it's time to purchase an additional internal disk-drive, and install it as a "slave" disk-drive in your desktop computer. It will become the 'E:' drive -- move your files from 'C:' to 'E:'.
Oct 17, 2010 | Computers & Internet
Installed Windows 7. Keep getting message of Low Disk Space on Recovery D drive. How do I fix this?
This message is coming because of the low space on the drive.So please delete the data from the drive.and empty the drive.
thank you
Sep 29, 2010 | Gateway GT4016 Desktop PC
Need to free up disk space on my acer aspire 5050
Allenu,
Has your laptop been working fine otherwise -- I mean, before the low disk space problems? If so, then I would suggest clearing out your Windows Update files, first. They are located in the C:\WINDOWS\ folder. For the most part, the filenames will begin and end with "$" (EX: $NtUninstallKB887472$).
If you have rebooted within the last few days (MS updates came out last Tuesday) and haven't seen any problems, then it should be safe to delete ALL of the $xxxxxx$ files in the C:\WINDOWS folder. If you have not rebooted or if you've had other problems, let's go another route. Reply back and let me know... and we'll go from there.
If this does not solve the problem, please don't rate the answer. I have other ideas, if we need to proceed in another direction.
Regards,
Char1ieJ
Nov 24, 2008 | Computers & Internet
Emachine i bought it 2/2008
windows vista is now a days not working so gud, so i advise u to hav windows xp service pack 2.. as soon as possible .it works tremendously.... it will help u.....!!!!!!
Oct 07, 2008 | E-Machines eMachines Desktop PC
Low disk space, how do i fix this problem,i have unistall some of the programs but stil having problem.when i restart the computer a pop up still diplay low disk space
low disk space because one of the drive is almost full it is having below 200MB space so this message will appear . i think so C drive is full just right click on the drive and make disk cleanup and in that select temporary internet files,temp files, recyclebin,compress old files and say ok it will remove all the files from u r computer which is not required finally space will get increased and message will not come
Jul 31, 2008 | Gateway Computers & Internet
Reformatting my compaq presario using my recovery disks
To turn on system restore, go into control panel, system. Click on the system restore tab. There you can turn on your system restore again.
Jun 22, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
