Question about ASUS P4S533-MX Motherboard
My computer does not boot from the ide section on the board but when u remove
What can u do to help me
  • bllackzz Oct 29, 2008
    no change was done to anything, and upon until now it does not work it show the amount of memory installed but it does not read the ide ports so i cant do anything
  • bllackzz Oct 31, 2008
    i've also tried that and still no response the light appears on the board as always. when the ide cable is not plugin the hrdd u can feel the vibration when its in it stops, when its not in the cd rom it opens but when connected it does not open
    Problem Solver:
  • 16 Answers
I need more info. When did this problem occur? Was it working properly before? Did you change anything in your CMOS/ BIOS settings?
Posted on Oct 28, 2008
  • Abhishek Papanna Oct 29, 2008
    if you can try removing each device and boot the comp using the other device. For instance remove HDD and try booting with only CD ROM and vice-versa. This way you can know whether any of your installed ide devices are causing the problem. After that let me know.
Hi the pc does not have a boot sequence menu and the os is corrupt
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
this is the boot sequence first boot device floppy
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
Jul 23, 2011 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
How to install windows xp to psrd1-vm mother board
if you want to install xp to your computer
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
hope this helps
Jul 03, 2011 | ASUS P5RD1-VM Motherboard
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
ASUS M2N68-AM SE2 GeForce 7025 Socket AM2+ MB built system. Works great with Sata hard drive. Removed my older 500GB IDE hard drive and CDROM from old PC. When i try to put both, or either 1 into to IDE...
Try to go into the bios and set the first boot device as your sata hdd. There will be a option in boot section of the cmos setup where the hdd drive order will be mentioned. If PATA is shown first press enter in the option select SATA and press enter save and exit changes things should go on fine.
Also check your pata hdd and cdrom specific jumper setting. For more help post your HDD model and make and cdrom model and the bios type
Dec 01, 2009 | Computers & Internet
How to remove vista from 1525 laptop and install winxp
you have to get in Bios. you will find HDD section. it must be IDE/AHCI section. you need to do IDE if you want to install XP. XP doesnt regognize AHCI SATA drives.
May 30, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
SATA II
Use SATA drives only
SATA and IDE do not mix
I had a SATA drive and tried to put IDE in as slave stopped computer from booting. removed IDE back to normal
Oct 30, 2008 | Intel Motherboard
PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
Oct 29, 2008 | Dell PowerEdge 1800 Server
Adding ide drive to a sata boot p4p800x xp Problem - ASUS P4P800-X Pentium Motherboard the system would not find ANY boot device
GaRoMo, 2 things. One change the pin on the IDE to a slave. Two open your bios. Asus board press the delete key every two sceonds untill the bios main menu opends. Go to BOOT section & make sure you have the SATA drive to boot. Your IDE should not be listed. Thats it.
Mike
Apr 25, 2008 | ASUS P4P800-X Pentium Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
ASUS P4S533-MX Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
