No sound on show time
Help i have no sound when i play files on nero show time on vista.
  • cybatron Oct 07, 2008
    It is nero 7 essentials.
    Sergeant:
    Champion:
  • 334 Answers
U get latest nero updates installed what verison nero 7 or 8 i hope none less will work right
Posted on Oct 07, 2008
  • nick helpap
    nick helpap Oct 07, 2008
    and are u on vista did u dl all updates form nerio .com u relly need ultra has way more video encoding i have it for 20 bucks paypal me i can send u it throw yahoo msg but try all updates 1st on nero site ok do windows updates drivers custum scan ect cheak for updates clik on nero icon take su to update center
Hi, got new pc, windows 7 64 bit, than got nero 10, nero cannot play movies on hard drive, try other programs and same thing, when i had xp, nero 9, there were no problems, i think nero 10 does not play...
According to Nero it is win7-64 compatible;
http://www.nero.com/enu/nero10-system-requirements.html
but there are reports of issues;
http://forum.my.nero.com/index.php?showtopic=7073
Hope that helps.
Feb 23, 2011 | Computers & Internet
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
Have Nero 7 essentials, all music files are not burning correctly, when they are played back from the burned cd, music files skip and music sounds distorted. When I burn the same music files from my lap...
Sounds like your Nero ASPI file is corrupt download a new version HERE
Replace you original DLL with the one above and restart Nero ROM this should solve your problem.
Jan 02, 2010 | Ahead Software Nero 7 Essentials Suite...
Dell 8100 windows media player says have no audio device
Uninstall Nero , update mediaplayer . install Nero back if every thing is ok
Oct 25, 2009 | Dell Dimension 8100 PC Desktop
I installed Nero 5 on my computer running Vista
Nero 5 won't run on vista or xp or xppro the software is not compatable with windows media player. even ep pro won't run with SP 2 installed.
Sep 30, 2009 | Computers & Internet
Nero 9 (and 7 & 8 too) all seem to be giving me the same problem on mix cd's (continuous play but with trackmarks). The blend between 2 files is just not quite right, it sounds like a slight jump or...
hi have you play the  files on there own to see if it there problem also it could be the cd drive you need to test both to see if this is the issue
Nov 23, 2008 | Computers & Internet
Whenever I try to play a video on my PC using Nero Show Time I get the following error Cannot play this media file (0x800040265) Why?
you can also try your video in windows media player or you can download the application in the Internet.. I think the name of that application is WINDVD but i'm not sure huh...
Jul 11, 2008 | Ahead Software Nero 6.0 (60045) for PC
Error in burning process
try to update the firmware for your dvd , it will help resolving this issue
Jul 01, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Optiarc DVD RW AD-5170A ATA not writing DVDs
sounds like your file is to large by the time it writes in and out or the disks a not to great
Mar 02, 2008 | Computers & Internet
Open Questions:
OUT DOOR lost love spell caster 078431819 spiritual healer in Ogies Kriel Delmas Polokwane Limpopo Alberton Isando Germiston DR OZ. MUSA TRADITIONAL & SPIRITUAL HEALER +2********** s blessed with powerful Spirits [ ancestral powers] to meet all your needs to satisfaction, all my services are beyond human imagination, and many have always asked me what is behind my services because of their effect to their problems. I can cast spells no matter how far the client may be and my spells are guaranteed to work in 3 days i am here to treat, heal & pay attention to whoever has problems using true African herbs with the guidance of my strong spiritual powers.love spells,wealth charms,natural luck and guaranteed win of tenders like lotto and casino BIND US TOGETHER, break up spells, BREAKUP SPELL, BREAKUP SPELLS, CHANGE YOUR LOVER'S MIND SPELL, CURSE REMOVAL, divorce spells, DO LOVE SPELLS WORK, FERTILITY SPELLS, fortune teller, gay love spells, GOOD LUCK, GOOD LUCK CHARM, HEALERS, HEALING, Herbalist, HEX REMOVAL, love spells, LOVE SPELLS THAT WORK, LUCK SPELLS, LUCKY CHARMS, Magic love spells, MAGIC SPELLS, marriage spells, NATIVE HEALER, POWERFUL LOVE SPELLS, POWERFUL MONEY SPELL Pinetown new germanyQueensburgh Tongaat Umbogintwin Umdloti Umgababa Umhlanga Rocks Umlazi Verulam Warner Beach Hattingspruit Madadeni Namibia Botswana dubai newlands Swaziland Greytown Muden Hluhluwe Ingwavuma Mkuze Mtubatuba St Lucia Ubombo Balgowan Boston Byrne Dargle Hilton Howick Impendile Merrivale Mooi River Epumalanga New Hanover Pietermaritzburg Richmond Wartburg York Noodsberg Harburg Harding RamsgateHibberdene Ifafa Beach Margate Palm Beach Park Rynie Pennington Port Edward Port Shepstone Scottburgh Sezela Shelly Beach Southbroom St Michael's-on-Sea Umkomaas Umtentweni Umzinto Umzumbe Uvongo Widenham Bulwer Cedarville Franklin Himeville Ixopo Kokstad Matatiele Swartberg Umzimkulu Underberg Ballito Stanger Salt Rock Amanzimtoti Cato Ridge Doonside Drummond Durban ekuPhakameni Hillcrest Illovo Beach Isipingo Karridene Kingsburgh Kloof La-Lucia La Mercy inanda kwamashu overport Rocks Westville Winkelspruit Phoenix Chatsworth Dannhauser Hattingspruit Madadeni Utrecht Louwsburg Mahlabatini Nongoma Paulpietersburg Ulundi Vryheid Empangeni Eshowe Mtunzini Richards Bay Bergville Elandslaagte Estcourt Ladysmith Winterton Dundee Balgowan Boston Byrne Dargle Hilton Howick Impendile Merrivale Mooi River Uvongo Widenham Bulwer Cedarville Franklin Himeville Sydney, Melbourne, Brisbane, perth, Adelaide, golden coast_tweed, maltland, Canberra, Queanbeyan, central coast, Hobart, Wollongong, sunshine coast, Geelong Twonsville, cairns, Darwin, Toowoomba, ballarat, bendigo, albury_wodonga, Launceston, mackay, rockhampton, bunbury mildura wentworth, shepparton_mooroopha, port Macquarie, tamworth, traralgon_morwell, orange, geraldton,ellenbrook, dubbo, Bathurst, busselton,warmmbool, Albany Devonport, Lismore, alice springs CONTACT HIM +2********** DURBAN
Mar 23, 2017 | Palm Computers & Internet
Computers & Internet Logo
109 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
