Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Right Door is making loud popping noise
The right door to my side-by-side refrigerator is making avery loud popping noise when it is opened and closed. sounds like it is in the hinge mechanism. Any ideas for a fix? I tried adding some silicon lubrication but it is still loud. thanks I have Kenmore 106.57282790 model side by side fridge. Right fridge door make big noise when opening and closing door. Any solutions?
  • 5 more comments
  • Anonymous Oct 14, 2008
    The right door will not stop when it opens but falls against the cabinet. It appears that the rubber washer on the top of the door when it hooks onto the refrigerator is cracked. Will this cause the door to not stop? If this is the problem how can I order the part or where is the nearest repair shop. I live in Starkville, MS 39759. Yhanks Rex Teel
  • Liz Wisniewski Apr 21, 2013
    Did you ever get that popping noise fixed ... I replaced the door cam on my Frig door. Than the popping started. I remember few years ago I replaced the door cam and it did the same. I don't think it should sound like that..My door Pops every time you open and close it..
  • Anonymous Mar 17, 2014
    model 253-52649305 lower cam rubs upper and causes a loud clicking sound. When I raise the door manually about 1/4 inch as I am opening or closing the upper and lower cam on hinge to not make noise.
    I want to know how to swap the door hinges from the right side to the left side
  • Anonymous Mar 20, 2014
    sounds like fan noise
  • Anonymous Mar 25, 2014
    Replaced control panel inside refrigerator but still binging
  • Anonymous Mar 31, 2014
    fridge makes a humming noise when door is closed fine when open. led light noisy when off
    New Friend:
We are going to do this today.
Posted on Jun 20, 2015
    Champion:
  • 210 Answers
Replace the door cam assy. and door stop.
Posted on Nov 05, 2008
2 Suggested Answers
SOURCE: Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Posted on Dec 25, 2008
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
HI,
Noise can come from these areas:
The inside of the freezer
The outside back of the refrigerator
The bottom of the refrigerator
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Aug 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Loud popping noise occurs when refrigerator door is opened
of course not! you paid good money for that fridge! can you train everyone to open the door only to 85 degrees?
Mar 08, 2013 | Refrigerators
Loud noise top right rear. sounds like a fan bearing going bad. Stops when doors are open.
when you open the door the fan stops......you diagnosed the problem without us.........have a good day.
Sep 18, 2010 | GE Profile PSW26P Stainless Steel Side by...
Right door makes a clicking sound
There is a nylon gasket at the bottom of the door hinge pin that needs replacing.
Jun 27, 2010 | Frigidaire FRS23KF7AB Side by Side...
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Squeaky Door on GE Arctica Refrigerator PSC23NGMB
Use Vaseline on the cam where the plastic slides across onother surface when opening door.
Nov 13, 2008 | Refrigerators
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
1,154 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
