Philips 26PFL5522D/05 goes into temporary standby after turning on
I'd appreciate some advice for an irritating problem I have with my Philips 26PFL5522D/05 LCD TV.
Most times (I'd say 4 out 5) after the TV has been on for about 5 seconds, it goes into standby for a few seconds and the powers back up. The remote doesn't work until the TV has powered itself back up.
Also very occassionally it goes into an "auto update mode" and tries to download a firmware update. I've left it in this mode for hours but it doesn't manage to download an update. The only solution I've found is to turn the TV off at the socket, leave for a minute or so and then turn back on.
Don't know if the 2 issues are connected so thought I'd describe both problems in the same post.
The Philips website offers no advice!
Any pearls of wisdom?
Thanks, Andy
  • 3130 Answers
SOURCE: TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Posted on Apr 02, 2006
  • 16 Answers
SOURCE: Planar PDP42BK Plasma TV
I searched for the c97 and c19 but can't find them, where are they located?
Posted on Nov 17, 2007
  • 5 Answers
SOURCE: Sharp Aquos turns itself off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Posted on Aug 16, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
SOURCE: 2 year old Phillips 42" Plasma TV won't turn on
Hi I had exactly the same problem, bought the above parts off ebay. The above solution worked and tv back to normal. the soldering is a bit tricky and there is a lot of screws holding the back on!
I'm trying to tune my Philips 26PFL5522D/05 tv digital channels without a remote. If i press the menu button I do not get 'Install' as an option in the drop down menu. Whats wrong?
I don't believe there are analog channels being broadcast anymore, or I know around here we don't have any, the set should pull up anything that is available without doing anything special to it. Below is a link that will explain it.
Are Analog Cable Channels Still Available Enlighten Me
Feb 11, 2018 | Philips Televison & Video
Philips 26pfl5522d/05 TV Channel issue
Just been on Philips Forum and there is a possible very simple solution. Press and hold the MENU button ON THE TV for about 20 secs. This should factory reset TV and allow storage/retrieval of channels to the '8k' store. See this page for more detail:
Now I have to ring my Dad who has exactly this problem!
Apr 03, 2012 | Philips Televison & Video
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Philips remote stopped working. 42PF7421d/37
my philips tv remote stopped working after i tuned a simple remote to it! so now my origenal remote will not worl model no. 26pfl5522d/05
Dec 31, 2009 | Philips Televison & Video
Television problem
Hi there!
I would start with power supply caps and regulators. However it could really be anywhere on the circuit, Philips TVs are error sensitive so I would recommend a repair technician. Good Luck, Jus004
Feb 20, 2008 | Philips 32PT6441/37 32" TV
Philips wide screen TV
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Nov 08, 2007 | Philips 28PW6506 28" TV
Philips TV 32PW9763/05
This is is due to a faulty resistor probably the B+(R950)..On the power supply control circuit..If you know how to use a multimeter you can easily find the faulty one...And replace it.However if you are not good at electronics i advice that you give it for service coz its not gonna cost you too much..Dont delay the repair as it can damage the more expensive components in the Tv.
Oct 16, 2007 | Televison & Video
Tv philips 28"
Hello, you (tech) can try this remedy - 1500 = fuse (250V/4A) - 3523 = resistor (47R) - 3527 = resistor (0.22R) - 3532 = resistor (2.2K) - 6500 = diode GBU4JL7002 - 6523 = diode 1N4148 - 7520 = circuit TEA1507P/N1 - 7522 = transistor BC847B - 7521 = transistor STP10NK80ZFP - 6526 = diode BZX384-C22 - 7515 = optocoupler TCET1104-G - 3526 = resistor (0.15R). - 3526 = resistor (0.22R). If you need more info please advice. Arpi
Jun 17, 2007 | Philips 28PW6506 28" TV
TV goes into standby after approx one hour
Capacitors that are going bad in the power supply is the usual problem. Six years, however, would be a long time for this problem to show up. Cheapest fix is (in order): (1) Replace all electrolytic capacitors in the power supply board - about $20.00 for parts. The really, really big high-voltage ones are probably OK unless you see a bulge in the top.
(2) Replace the power supply board entirely (with new one - not used from eBay) (3) Come back here if these don't fix it. I have fixed many TVs with this issue and 90% is capacitor related.
Jan 15, 2018 | Philips 36PW9525C 36" TV
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
