Question about Canon Office Equipment & Supplies
Fax machine collects faxes in memory and will not print out automatically. We'd like it to print automatically, time sensitive information can be locked in hold before we realize that we are needing to push the reset button to get the faxes to print. This is a Canon Faxphone L80 model. Is there a way to program the fax to print automatically? I can't find a way to set the fax only mode - this may be because it shares a phone line with our credit card machine. We do have it set on the Fax/Tel mode. Any suggestions?
    Genius:
  • 2,120 Answers
I feel your pain I think Radio Shack sells a fax / phone switch that may solve your problem
Posted on Oct 08, 2008
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
MY FAX MACHINE CAN NOT RECEIVE FAX FROM OTHER, THE DISPLAY IS FAX MEMORY FULL, HOW TO SOLVE?
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
My fax machine can't receive message, "fax memory full"...how to erase the fax memory?
It will depend on the model and make and you have not supplied that information.
If this information in memory was received information then the machine should print out the documents as long as there is nothing in the display saying it needs toner, paper etc, etc.
If it is not received information in memory then it can only be scanned information for copying or transmitting....again, not knowing make or model...you should be able to use your users manual and delete the pages you have stored into memory.
Oct 07, 2010 | Office Equipment & Supplies
How do i get a confirmation of a fax sent over a month ago?
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to
print automatically also.
1. Press Report/Help.
2. Choose the report you want by using !".
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Aug 25, 2009 | HP 1040 Plain Paper Inkjet Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
I am still unable to receive faxes that are printed automatically when they arrive. they mst be going to memory and i cannot get them to print out of memory. can yo please help me. i paid for this service...
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Jul 17, 2009 | Canon MX310 Office All-In-One Printer
Reg. printing of memory received messages
Yes, after refilling the cartridge, fax in memory automatically print out with charms. :) thanks for your help.
Aug 18, 2008 | Office Equipment & Supplies
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
old marine
old marine
