Question about Schumacher 10 Amp Fully Automatic/Manual Charger by
Troubleshoot car battery charger
Turns on but does not charge the battery
indicator needle does not move to lower amp levels
fully charged light does not come on
how to find out the problem
how to repair
any general schematics or wiring diagrams for chargers
  • kakl Dec 24, 2008
    I have the same problem. I have tested the ampere selector switch and the same to be continuity across every blade and it doesn't matter whater ampere it is set on. Could this be the problem?
4 Suggested Answers
Thermo King
  • 593 Answers
SOURCE: is the 10 amp se-40ma battery charger to big for
A battery that might sit for a month at a time, would only need a trickle charge or about 1 amp, a charger of this type can stay hooked to the battery for the whole month. A 10 amp would be for a quick charge or only about 4 - 12 hours depends on how fast the battery lost the charge. A 10 amp charge would cook the battery if left for days.
Posted on Mar 26, 2010
  • 122 Answers
SOURCE: lost manual ...how long should i charge my riding
The SE40MAP has an automatic shutoff when battery is fully charged.
Posted on Jun 07, 2011
  • 122 Answers
SOURCE: I have a Schumacker Model
Quite simply - the unit has suffered component failure - most likely more than one. Capacitors are the usual source of noisy 'bang' or 'pop' sounds, followed by diodes and bridge rectifiers. If you have some knowledge of electronics, you can attempt repair, but, if none, I suggest leaving possible repairs to someone who does.
The humming sound you hear is the transformer under stress, and, if left connected, it too will die.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Reading the charging gauge for a jazzy 1103 ultra
if you mean the lights, they are just a tool to estimate usage, if you mean the amp guage on the rear, depending on battery state, the needle can start at 2-5 amps and slowely go down as batts are fully charged, if left plugged in the charger will do a random maint charge, and move the needle slightly
Dec 08, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
On my unit the guage does not seem to move upward as the battery charges or is the line to the far left indicate a fully charged battery
The meter on the charger indicates how much power the charger is putting out. The far left is zero (0) output, meaning fully charged. There should be numbers on the meter.
May 30, 2011 | Schumacher & Fast Charge Starter Charger
Battery is fully charged but when I turn ignition key nothing happens, on light does'nt come on and needle does'nt move battery level
Has the scooter been sitting unused for a while? If so, the gel inside the rechargeable batteries may have gone solid. When you connect the charger, the light shows green indicating the batteries are full, but instead of being full of power, they are full of crud. The scooter can sit for just a few weeks and this will happen. If the batteries are new or have been properly maintained, try checking your fuses and all the connections/leads as this certainly sounds like a power problem.
Oct 18, 2010 | Health & Beauty
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
Jan 29, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Schumacher 10 Amp Fully Automatic/Manual Charger by Logo
311 people viewed this question
Top Schumacher Hardware & Accessories Experts
jdthefixer
Are you a Schumacher Hardware and Accessory Expert? Answer questions, earn points and help others
