Question about GE JGRP20 Gas Single Oven
Ge extra large self cleaning oven xl44 mode jgbp28ded1wh
My broiler works but the oven will not get warm. I do not have a manual to try to trouble shoot the problem.
    Problem Solver:
  • 5 Answers
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
Posted on Apr 01, 2009
GE gas oven XL44 JGBP29GES1WW not enough heat
I suspect a faulty ignitor. It must draw a certain amount of amps to open the gas valve
XL44
Jun 09, 2010 | GE Ovens
Ge electric broiler inoperative
Link to manual
check page 22 for self cleaning oven
(door is latched )
make sure clock and timer are operative
Dec 20, 2007 | Ovens
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
Oven will not get out of the self-cleaning mode
Ok, unplug the unit for 5 minutes to reset the main circuit board. if the error continues to plague the unit, replace the control board.
May 31, 2009 | GE Ovens
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Xl44 gas
two things either hte clock(control ) assy not sending powerdown to the igiotr, or hte valve that the ignitor is connected to onst nay good, unplugh the unit andwitha meter try testing the 2 wire connections on the top of the safety valve( i wire goes to the ignitor nad the other is a neutral wire htt hooks downt to under the valve for the broiler, you should show continuity across those to leads, if not your valve is no good and will need replacing
Mar 20, 2008 | GE JGRP17 Gas Single Oven
1988 General Electric Oven
Sounds like the the thermostat. This is the dial item which controls the temperature. Removal and replacement is usually straightforward. Turn off the power before starting work.
Dec 28, 2007 | Ovens
GE JGRP20 Gas Single Oven Logo
640 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
